Sda effect not working correctly.
Refefer
Refefer Posts: 1,280
edited August 2006 in Vintage Speakers
Let me give you the background. My SDA-1Bs have been in use for about a month now and I have loved ever second of them. However, one thing I noticed is that my left one's "SDA effect" sometimes works, sometimes doesn't. The same piece will often time have a nice broad sound stage, and other times will essentially cut off not far outside the speaker.
I have the cable of course and it's securely connected. All 4 midrange drivers are working even when the "sda effect" is not.
Any ideas what could be the problem? Possibly a crossover issue or an internal cable loose of some sort?
Lovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II
Post edited by Refefer on
    F1nut Posts: 51,997
    edited August 2006
    Polk has an SDA trouble shooting guide they will provide for the asking. While you're waiting for that to arrive, pop out the drivers, check for loose or oxidized connections at the speaker and the crossover.
    I will say that you are mistaken in thinking that the SDA drivers are working when you're not getting the proper soundstage. Because it's a sealed cabinet, they will move to the music even when not actually working.
    heiney9 Posts: 25,497
    edited August 2006
    Definetly get the trouble shooting guide. But I do wonder if the issues you are talking about happen while playing the same piece of music at different times. With some songs the SDA properties are very apparent, but on others it's almost non-existent. Are you talking about one piece of music that sounds different each time you listen to it or, that on some songs the SDA seems to be missing compared to other songs you listen to?
    edited August 2006
    ........NM.........I went back and reread the thread and answered the question in my previous post :(:confused: . Do as F1 suggests as it's a good starting point.
  • schwarcw
    schwarcw Posts: 7,358
    edited August 2006
    One simple test is to sit down in your listening position with the system playing at your normal levels. Have someone disconnect the reconnect the interconnect cable a couple of times while your listening. You should hear a big difference in the size of the soundstage when connected vs unconnected.
    Carl
  • Refefer
    edited August 2006
    I'll grab the guide and check out the wires, thanks.
    Polk SDA-1B,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    Computer Rig
    Polk SDA CRS+,
