polk infinity comps sub amps
Big10Fan
***Polk c300.2 1 month old(they sent me a new one in warranty, and i used it to see if it worked)$250 shipped OBO
150 Watts RMS x 2 At 4 Ohms
220 Watts RMS x 2 At 2 Ohms
550 Watts RMS x 1 Bridged Output At 4 Ohms
Stereo Or Bridged Mono Output
4-Ohm Stable In Bridged Mode
Tri-Way Capable
Maximum Dynamic Headroom (MDH) Power Supply
Requires 4-Gauge Power And Ground Leads
Variable High- And Low-Pass Crossovers, 50-250 Hz, 18 dB/Octave
Subsonic Filter At 15 Hz, 24 DB/Octave (Only Operates With Low-Pass Filter Activated)
6-Way Smart System Protection Circuitry
Pre-EQ Switch Optimizes The Crossover And Bass Level
RCA Inputs Accept Both Speaker- And Preamp-Level Input
Preamp Outputs
Optional Remote Subwoofer Level Control
13-3/8W x 2-9/16H x 9-3/4D Inches
***polk c500.1 9months old with a minor scratch I can get a pic of. $250 shipped OBO
Amplifier Type: Mono
RMS Power @ 4 Ohms: 350W x 1 @ 4 ohms
THD at 4-Ohm RMS Power: 1%
Bridged RMS Power @ 4 Ohms: 500W x 1 @ 2 Ohms
Speaker Level Inputs: yes
Preamp Outputs : yes
Built-In Crossovers: LP
Bass Boost: 0-18 dB
Frequency Response: 20-200 Hz
Signal to Noise Ratio: >105 dB
Fuse Rating: 2 x 25 amps
***polk mmc6500 components used for 3months, still in great shape. $150 shipped OBO
Sensitivity: 90 dB
Frequency Response: 43-25,000 Hz
Recommended RMS Power: 125W
Peak Power Handling: 250W
Impedance: 4 ohms
***infinity 10.1d DVC used 9 months still in great shape. $75 shipped OBO
Rec. Sealed Box Dims: .6 - .6 cu.ft.
Rec. Ported Box Dims: 1 - 1 cu.ft
Free Air Usage: not recommended
Sensitivity: 94 dB
Frequency Response: 18-150 Hz
Recommended RMS Power: 350W
Peak Power Handling: 1400W
Impedance: dual 4 ohms
PLEASE MAKE OFFERS dont just shrug it off if its too high.
Tri-Way Capable
Preamp Outputs
Bass Boost: 0-18 dB
Sensitivity: 90 dB
Impedance: 4 ohms
Sensitivity: 94 dB
