SVS Subs Plus vs Non-Plus
SolidSqual
SolidSqual Posts: 5,218
edited August 2006 in Speakers
Hey,
Does anyone have any experience with SVS Plus subwoofers vs the regular ones? I have two pb-10s, but plan to move one to a bedroom system. I want to know if I need the power of the Plus subwoofers or if I can get by on the non plus units. I'm considering the 20-31. Any thought?
Post edited by SolidSqual on
  • Holydoc
    Holydoc Posts: 1,048
    edited August 2006
    Could you clarify your question a bit? The SVS PB series is the NSD BOX subwoofer. That is what you own now.
    Are you asking if:
    1) You should switch to the Cylinder series?
    or
    2) What the difference is in the plus series cylinder subs and the non plus series cylinders?
    or
    3) What the heck is the 20-31? I know they make a 20-39 or a 25-31. I did not know they made a 20-31.
    Sorry...just a bit confused what your actual question is.
    Holydoc (Home Theatre Lover)
    __________________________________________
    Panasonic -50PX600U 50" Plasma
    Onkyo -TX-NR901 Receiver
    Oppo -Oppo 980HD Universal DVD Player
    Outlaw -770 (7x200watt) Amplifier
    PolkAudio - RTi12 (Left and Right)
    PolkAudio - CSi5 (Center)
    PolkAudio - FXi3 (Back and Surround)
    SVS - PB-12/Plus (Subwoofer)
    Bluejean Cables - Interconnects
    Logitech Harmony 880 - Remote
  • Sherardp
    Sherardp Posts: 8,038
    edited August 2006
    If youre talking PB 12 Plus 2, its a monster, if you have the space for it. Its well worth the purchase. I dont have any regrets at all towards my purchase. Outstanding product
  • ohskigod
    ohskigod Posts: 6,502
    edited August 2006
    wether going the plus route is worth it is going to depend heavily on the size of the room.
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
