Suddenly no sound
zeke14
zeke14 Posts: 7
I have a Denon AVR-1801 Receiver and a Sony CD player with 3 Polk speakers. I have the Receiver set on Auto. I can play music CDs with no problem. Last week, I put in a movie and I have a great picture but no sound. I have gone through the manual and punched every combination I can think of and no luck in getting sound from the movie. I also checked the Tuner, and no sound there either. What have I done? Any help is appreciated, my frustration level is at a critical mass and I can hardly go back to my system.
Zeke
Post edited by zeke14 on
  • zeke14
    zeke14 Posts: 7
    edited August 2006
    The hook-up from CD/DVD player to Receiver is coaxial and has never been changed in the 5 years I've had the system. The CD/DVD player is a 5 disk carousel from Sony and I can not remember the model number.
    Zeke
  • 808Tech
    808Tech Posts: 10
    edited August 2006
    I'd say, do a master reset and get everything back to default.
    Hmm...
    James
  • amulford
    amulford Posts: 5,020
    edited August 2006
    Is the mute engaged? Is the digital input selected correctly?
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited August 2006
    Anthony, there was a time I would be all over both of those questions!!!:D
    Talking about inputing digits and if mutes are engaging, the shame of it all.
    So Zeke you get it running yet???
    RT1
  • Skynut
    Skynut Posts: 2,967
    edited August 2006
    Zeke
    My old sony 5 disc died. All of the sudden it would not recognize DVD's. It would still play music but not DVD's.
    Perhaps yours had a similar issue?
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • zeke14
    zeke14 Posts: 7
    edited August 2006
    Thanks for the suggestions. No, I have not been able to get sound from DVDs, and my tuner won't put out sound for the radio. Mute is not turned on and I tried to go back the default settings. I can only attempt to reconfigure the settings for about an hour, because my frustrion level gets to a dangerous point. I'm going to swallow my emberassment and pay someone to come to my house and see if they can set-up the system.
    Zeke
  • reeltrouble1
    edited August 2006
    zeke,
    I am not a Denon 1801 expert, you have a set up problem, I know you are at wits end with the thing, but you need to go back to square one, unhook everything and then add back one piece at a time and check to see if it works as you go along. Did you try hooking the DVD to the CD input you are using for sound? Just run the video cable straight away to the TV and see is your player is working. You need to try something different to get your brain out of the rut and your juices flowing.
    RT1
