Need help-looking to buy new subs
drtre
drtre Posts: 3
edited August 2006 in Car Subwoofer Talk
I bought a package at Best Buy for about 320 dollars which came with almost everything I needed for my subwoofers in my car, the enclosure, amp, subs, and I bought the amp kit seperately. Somehow after two months my subs blew unexpectedly and I ran it by Best Buy with only the warranty for INstallation and they said they would need the actual receipt to replace the subs. So I Looked and looked for it and can't find it anywhere. I know, stupid me. Crap happens though. So Now I am stuck with an amp, enclosure and amo kit but no subs and I started looking for new ones and I found some that have gotten really good reviews but I don't know how well it would work with my previous equipment. I'm still pretty ignorant to how all this works. BUt here is the enlosure, amp kit, and amp I have.
Enclosure
http://www.bestbuy.com/site/olspage.jsp?skuId=6294388&type=product&productCategoryId=cat03082&id=1072287759557
Amp Kit
http://www.bestbuy.com/site/olspage.jsp?skuId=7662246&type=product&productCategoryId=pcmcat30100050007&id=1134701342298
Amp
http://www.bestbuy.com/site/olspage.jsp?skuId=7707608&type=product&productCategoryId=cat03085&id=1138085847096
Last but not least these are the subs I was looking at. I just want to know how it would sound with all my previous Equipment. Any Advice is apprectiated.
http://www.circuitcity.com/rpsm/oid/117483/originURLEncoded/http%253A%252F%252Fwww.circuitcity.com%252Fccd%252Fcategorylist.do%253Fcmpstr%253D%2526bMore%253D%2526N%253D20013088%2B20015481%2B20013093%2526No%253D20%2526catOid%253D-13093%2526link%253Dref%2526PAGE_ACTION%253D%2526c%253D1/rpem/ccd/productDetail.do#tabs
And if this helps these are my old subs, I dont really know how much better it would sound with those other subs.
http://www.bestbuy.com/site/olspage.jsp?skuId=7042032&type=product&productCategoryId=cat03081&id=1099396539135
Thanks!
Post edited by drtre on
  • MacLeod
    MacLeod Posts: 14,358
    edited July 2006
    The Kicker subs will be about 10 times the sub those Power Acoustic were. Kicker is a competition level manufacturer where PA is a budget, entry level brand.
  • drtre
    drtre Posts: 3
    edited July 2006
    so im guessing those would be worth it, but my main question out of all this is would it work well with my previous equipment like my amp and enclosure and amp kit
  • MacLeod
    edited July 2006
    No.
    The box is too small. Youd need about a 1.6 ft3 box. Plus, the amp is way too small. Those subs need at least 500 watts each to push em properly. The 280 of your amp wont do them justice.
    Get a pair of Polk Audio DB124's. Theyd match up better to the amp but the box would still be a smidge too small. They would still work tho but theyd have a response hump in them.
    Thats actually an odd box. I dont know of too many 12's that can work in a .6 box which is what youd need if you want to stick a pair of them in that 1.2 box.
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited July 2006
    The box specs say that it is 1.25 cu ft of air space per woofer. You could get some nice woofers that would perform very well in that box.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • drtre
    drtre Posts: 3
    edited July 2006
    New thought, What if I purchased the same subs I had before but along with them I bought another Amp. How would that work out
  • PaintballFREAK
    PaintballFREAK Posts: 28
    edited August 2006
    what would it help. unless the amp before really really sucked
  • 1996blackmax
    edited August 2006
    I would take this opportunity to get some better subs....
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • Narco_snow
    Narco_snow Posts: 3
    edited August 2006
    whatever you do... don't buy from best buy... i used to work for them and if you're lookin to get ripped off beyond your wildest dreams, then go for it. if not, find either a real local car audio shop, or buy offline
