Sub Behind tv?
tecmo04
tecmo04 Posts: 421
im concidering putting my velodyne ct120 behind my tv (which is in the corner of my room). The only problem is im not sure if it is video sheilded. If it isnt will it destroy my tv? What other precautions should i take?
Thanks in advance for all the help!
Post edited by tecmo04 on
  • Sherardp
    Sherardp Posts: 8,038
    edited July 2006
    It wont destroy the tv, but you will see like a green screen or bars in your picture which indicates speaker interference. My suggestion is trash it and get a SVS, corner load it and smile. Just kidding, velodyne are excellent products as well. You also want to make sure any vibration does move your TV off its stand ect, I think you would get more bass with a corner loaded setup. Just my thoughts.
    VR3 Posts: 29,554
    edited July 2006
    My sub has a huge magnet and is like 1' under my TV and slightly to the right... no distortion of any kind.
  • millerman 3732
    millerman 3732 Posts: 1,488
    edited July 2006
    is your tv a tube or a projection model?
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Toshiba HD-XA2 (HD-DVD, CD)
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi 10 (bi-amped)
    Polk CSi5 (bi-amped)
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
    TV Rig: Samsung 50'' 4k display
    Polk Signa-1 Surround bar
    VR3 Posts: 29,554
    edited July 2006
    tubey
  • millerman 3732
    edited July 2006
    the reason i ask is i have a projection model and when I had my sub sat to close to the tv the picture would shake when my sub really started digging deep or when I cranked it up alittle to loud....not cool
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
  • MADGSF
    MADGSF Posts: 603
    edited July 2006
    I have my PC-Ultra sitting about 18 inches from my TV with no problems, it's a tube TV.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
  • tecmo04
    tecmo04 Posts: 421
    edited July 2006
    mine is a rear projector so im not sure. did that green tint u were mentioning go away when the sub is removed? does the shaking of the guns ruin the tv??
  • danger boy
    danger boy Posts: 15,722
    edited July 2006
    if you have a green tint on your tv you need to degauss it.. on some TV's this happens if you turn it off then turn it back on.. but not all tv's have the ability to degauss
    PolkFest 2012, who's going>?
  • tecmo04
    tecmo04 Posts: 421
    edited July 2006
    so i finally got around to moving the sub behind the tv. I think i like it more. It used to be in the opposite corner, kinda isolated. Now it is behind the 3 main speakers. Bass sounds much more in sync i guess is the best way to describe it. Ill try it for a little and see what happens to the tv.
    Thanks for the help!
    p.s. do you think putting the sub on a slab of mdf would be a good preventative action to reduce vibration for the tv?
  • Sherardp
    edited July 2006
    try the rubber feet heres a link from parts express, instead of drilling into the cabinet try to use double sided tape, it should work. this will reduce vibration and keep the sub from "walking" during heavy bass tracks/music.
    http://www.partsexpress.com/webpage.cfm?webpage_id=3&SO=2&&DID=7&CATID=48&ObjectGroup_ID=139
  • univera
    univera Posts: 848
    edited August 2006
    Yea, I used a sub for a t.v. stand for a 20" POC t.v. during a transition phase when a former roomate took the 32" (****.) Anyhow, the green in the corners never went away.
    UNIVERA
    Historic Charleston SC
    2 Channel:
    SDA-SRS's RDO tweets
    Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
    Anthem Pre 2L w/E.harmonix platinum matched 6H23's
    CDP- NAD C 542
    HT setup:
    AVR: NAD T 773
    Rears: Polk LC80i
    DVD: Toshiba 3109 dual tray
    Subs: Velodyne and M&K
    T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
    Conditioner: Panamax M5100EX
    Master Bedroom Sony 40KDL-XBR3
    "I love it when a plan comes together." Hannibal Smith, The A-Team
  • tecmo04
    tecmo04 Posts: 421
    edited August 2006
    im not worried about the sub walking, becuase my tv is in a corner and the sub barley fits behind it. Im just worried about vibrating the tv/floor. THe woofer is facing the back of the tv (43" rear projector). i just dont want the vibrations to unalign the guns, yada yada yada, more stuff im a noobie at...
