Will CS1 sound ok with rti line?
First time polkie here!!!
I just bought a complete rti setup (RTi8's front, CSi3 Center, FXi3's surround and Velodyne DLS-5000R sub), but I just discovered the CSi3 it too big for the space where I am putting my center speaker. My opening is just slightly bigger than 19", and the only Polk Center I can find that will fit in there is the CS1.
I am sooo disappointed right now. I'm affraid that having the CS1 for a center won't sound right with my other speakers. Anyone have any experience with this speaker? Or even in this same application? Am I in for a big dissapointment if I get the CS1, or is it going to work out ok? If it helps, I have a Sony STDR-3000 ES receiver, so I'm hoping that worst case I could maybe try to adjust the sound levels on that specific speaker on the receiver.
Any advise would be greatly appreciated.
Post edited by rev29K on
wont work and they dont matchShoot the jumper.....................BALLIN.............!!!!!
Welcome to the Club Polk Forums rev29K! Not a good match. Give it a try if they'll exchange it. In the long run you may need a bigger stand. You'll be happier in the end with a good center match!Carl
The problem is that the opening in my entertainment center is the only place I can put the center, and it's only 19" wide. The speaker isn't on stands, it's going to be in a square opening in an entertainment center.
How tall is your opening. There is always the option of using a single RTi4 or RTi6 to utilize as a center channel. I've done this at several different times. If your space will allow it, go with the larger 6.Tschüss
Zach -
Well, I went ahead and just got a CS1 for the center. I hooked it up, just finished hanging my fxi3's, and so far everything sounds great. Of course I'm just listening to music in 5 Channel right now. But so far so good. I'm having a hard time noticing any substancial differences. Any idea of a specific test that might show any flaws with using the CS1 as a substitute?
BTW, in case I haven't said thanks to everyone for the help --- Thanks!! -
It all depends on what sounds good to you. Congrats.
