Onkyo TX-SR603 vs. SR703
tbone1
I am fairly new to home theatre and this is my first post. I recently bought a Pioneer Plasma TV and I am wanting to now purchase a reciever, DVD, and speakers. I have just about narrowed it down to a set of RTI 10s with an appropriate center channel, sub, and rear bookshelves. I am going to buy it all piece by piece starting with the reciever. I have really been looking at the Onkyo 603 from crutchfield thats on sale right now for $399 normally $499. It seems like an awesome deal for this reciever. My question is will this reciever be enough to push the RTI 10s. Or do I really need to step up to the 703. The only real difference is 10 watts per channel from 90 to 100 and the added THX certification. There is a significant price increase and I don't want to pay it if there would not be a noticable difference in performance. Any input or advice is appreciated. Thanks.
Post edited by tbone1 on
at that price, THX means nothing. It's an Onkyo receiver, and 90/100 watts per channel also means nothing. You have RTi10's. Get a separate amplifier to do them justice, or at the very least a decent brand of receiver that's honest with it's wattage specs.
Welcome to the forums. -
If you are limited to only those two onks, then consider the 703 because it has pre-outs.Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
Mike682 wrote:If you are limited to only those two onks, then consider the 703 because it has pre-outs.
Yeah, for when you decide you want an external amp. -
and you will do so eventually...Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
Thanks for the responses. It seems to me that either my choice of reciever will be severely underpowered or I have chosen too large of speakers for my purpose. The reason that I am leaning toward what I am is because of my budget. I have budgeted $400-$600 for a decent reciever and around $1800-$2000 for speakers. For this price range, am I going in the wrong direction. I am probably wrong but I thought that the point of THX cert. was basically to certify that it really will produce what is says so they can't lie about the specs. As I said before, all comments are appreciated.
tbone1 wrote:Thanks for the responses. It seems to me that either my choice of reciever will be severely underpowered or I have chosen too large of speakers for my purpose. The reason that I am leaning toward what I am is because of my budget. I have budgeted $400-$600 for a decent reciever and around $1800-$2000 for speakers. For this price range, am I going in the wrong direction. I am probably wrong but I thought that the point of THX cert. was basically to certify that it really will produce what is says so they can't lie about the specs. As I said before, all comments are appreciated.
The point of the THX certification is that it guarantees that the receiver will perform to a certain level given it is connected to a certified THX system. It does not mean that the specs have to reported in a certain format that is standardized in any way(notice I did not say the specs were wrong. I am just saying they may be misleading).
For example, Onkyo reports the SR703 to output 100watts/channel of power. Does this mean with all seven channels running at one time? Does it mean with just one channel running at one time? Onkyo leaves this vague. When companies leave this vague, they are doing it for a reason. Typically this is to fool the consumer into thinking that the receiver will perform at 100watts output on all channels at the same time while it cannot do even a portion of that.
What you forgot to mention in your price comparison of the two receivers were that the 703 also contains pre-outs, 7.1 multi channel input, cinema re-eq, more audio inputs, more digital inputs, pure audio mode, a phono input, and a backlit remote. All the above features are not included on the cheaper one. These are some significant items for expansion purposes.
Therefore for upgradability and a receiver that you can live with for a while, I would select the 703.Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
I am living with the 601, which I got for $300 and I wanted the 701 Onkyo which was a lot more than I wanted to pay at the time. I wish I had the 701 instead, but I am content, eventhough I am holding my RTi10s back. A new pre-amp and seperate amp are in my near future.
My advise to you, if those are your choices, get the 703 onkyo, because it allows you expandability since it has a built in pre-amp. It will hold you over until you get the big boy powerhouses that you need to make those RTi10s do the damn thing. Good luck to you.Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD -
Thanks to all of you who responded. Great advice. You have prevented me from making a mistake that I may have regreted in the future. The info that you provided are things that I had not thought of because I didn't know to ask. I ordered the 703 today. Thanks again.
DONT GET AN ONKYO! I cannot stress this enough. I dont care if it's the TX-NR1000, it's still a piece of crap. Onkyo is junk, take it from me. I have one and I hate it! But I cannot afford to go out and get another receiver. I would try Denon, Yamaha, or Pioneer Elite before I would go out and get a damn Onkyo! Trust me dude I own one and I will never buy another product from Onkyo.Don't forget to look at My Home Theater
Receiver - Onkyo TX-SR503
Fronts - Polk Audio Monitor 40
Center - Polk Audio CS1
Surrounds - Paradigm Cinema ADP
Subwoofer - Velodyne VRP-1200 -
josh_parsons626 wrote:DONT GET AN ONKYO! I cannot stress this enough. I dont care if it's the TX-NR1000, it's still a piece of crap. Onkyo is junk, take it from me. I have one and I hate it! But I cannot afford to go out and get another receiver. I would try Denon, Yamaha, or Pioneer Elite before I would go out and get a damn Onkyo! Trust me dude I own one and I will never buy another product from Onkyo.
What issues have you had with yours? (just curious)I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore -
zombie boy 2000 wrote:What issues have you had with yours? (just curious)
Same here. I am very curious to hear.Holydoc (Home Theatre Lover)
true because when you buy the lowest end model they have, it speaks for the entire line. I saw a Chevy corsica on the side of the road today with engine problems... stay the hell away from the corvette!!! It's a POS too. I would know, I saw a corsica dead!Never kick a fresh **** on a hot day.
denon 3806 AVR, CSI5 center, FXi3/5 surrounds, Rtis 4/6s for rear surrounds, svs sub, 3xM2200 monoblocks for front stage amps. Anything along that line and youre good.Shoot the jumper.....................BALLIN.............!!!!!
My first processor was an Onkyo 701 and it was a nice first foray in HT. Don't get anything without pre outs and I would definitely only get used at this point because if you are as crazy as we are ( and you know you are!:D ) there WILL be upgrading in your future.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Good deal. The 703 will hold you until you get an external amp.Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
No problems with my Onkyo, congrats on your new receiver.
