File Sharing
Aaron
Aaron Posts: 1,853
edited February 28 in Clubhouse Archives
Does anyone know how to do file sharing over the internet such that you can access the shared folder as if it was on your local machine (like mapping a drive)? Can MS Networking support this? It doesn't seem like it. The only way I've found to do this is to set up a VPN, but that unfortunately routes all your internet traffic through the VPN (and hence the remote computer's internet connection). I'm looking for an easy way to share a repository of documents with my friend so we can both easily work on them.
Aaron
Post edited by RyanC_Masimo on
  • phuz
    phuz Posts: 2,372
    edited June 2002
    You can share files over the internet the same way that you do on a local network, at least as long as there is no firewall between you and the internet.
    You could also try setting up ftp real quick. I'd have to know more about your situation to better help you. Just remember that the internet is just like any other network for the most part.
  • phuz
    phuz Posts: 2,372
    edited June 2002
    Ick, I'm not sure if that halped much. heh
    Just map a drive. It's that easy. For security reasons I don't recommend it though, unless you make sure that you've killed all the admin shares.
    You can always put em on an ftp server somewhere. Thats how most people do it. Your ISP probably already has ftp (or http) space for you to use.
  • Ron-P
    Ron-P Posts: 8,520
    edited June 2002
    Just make sure you use protection.
    Peace Out~:D
    If...
    Ron loves a film = don't even rent.
  • RuSsMaN
    RuSsMaN Posts: 17,987
    edited June 2002
    I use WarFTP, eff the shared folders.....
    -R
  • Aaron
    Aaron Posts: 1,853
    edited June 2002
    FTP is definitely not what I want to do. I want to be able to easily work with these files from within any application (be it Windows Explorer or MS Word). Phuz, what info do you need? I'm on a cable modem with no firewall and my friend is also on a cable modem but connected through a router (which has a firewall, but port forwarding and such is configured). We both have dynamic IP's, but we're using DNS2Go to get around that problem.
    So, how do I map a network drive over the internet? Can my friend just set up a standard MS Networking share? This is what I'm entering as the network share and it's not working:
    \\his_host_name.d2g.com\share_name
    Aaron
  • HBombToo
    HBombToo Posts: 5,256
    edited June 2002
    I'm with Russ!
    ***WAREMTAE***
  • RuSsMaN
    edited June 2002
    The only way I did it with mapping a drive to a freakin folder, was to setup personal web server, and share the folder(s). I could then map to the UNC path.... \\hostname.whatever\sharename.
    Then I could drag and drop, like any other folder.....
    Cheers,
    Russ
  • dylan
    dylan Posts: 453
    edited June 2002
    Have you tried pinging his IP? I wonder if it's failing (like firewall issue on his end) before the name resolution part...
  • Aaron
    Aaron Posts: 1,853
    edited June 2002
    Ping doesn't work, but I believe that's because he has it disabled. We successfully set up a VPN, so (most) everything network-wise seems to be working.
    Aaron
  • dlew308
    dlew308 Posts: 530
    edited June 2002
    And to think Bill Gates thought the internet would fail...
    P2P baby!
  • phuz
    phuz Posts: 2,372
    edited June 2002
    I'm with Russ to, but if you really want to map a drive then it can be done. You are on the right track, but with the router and DNS to go running... it's going to be painful. Just set up a web share like Russ said. I could do it all easily, but it's not easy to type it out on a BB. :)
    You are on a cable modem with no firewall? Ouch. Get something like Blackice Defender or Zone Alarm at least.
  • phuz
    phuz Posts: 2,372
    edited June 2002
    Aaron
    He would have to map a few ports (at least port 139) and most likely disable a lot of the firewalling features for the sharing to work. Oh well at least you have a work around. heh
  • Aaron
    Aaron Posts: 1,853
    edited June 2002
    I usually run the Windows XP firewall, but I've had it disabled while we've been working out our networking issues. I also have a router with a firewall (which seems more like a firefence), but I'm not using it right now. We'll try out the web share tonight and see how that works out. Thanks.
    Aaron
  • goingganzo
    goingganzo Posts: 2,793
    edited June 2002
    get windows xp prow ot has remote desktop you can control another comp form across the country or wherever i have xp prow on my comp and it works great to control my other comp ps you can do a dual prossesor setup to
  • Aaron
    Aaron Posts: 1,853
    edited June 2002
    We both have Windows XP Pro (and all the other Windows OS's for that matter), but I want share files, not control a computer.
    Aaron
