DVD player plays in Black and White
edited July 2006 in Electronics
Has anyone here had this problem before? I have ran into this twice now on different DVD players. Last time I returned the player to Costco and got another one but I have now placed the DVD player with a combo VHS/DVD player and now it has happened again. They seem to work fine for awhile and then they only play in black and white. The VHS side of the player still works fine.
I play CD's in the DVD player and I play a limited number of DVD's. The TV is an older (purchased around 1997 or so) Sharp CRT. Is it my TV or something else that is causing this to happen?
Post edited by boxxkar on
Welcome!
    edited July 2006
    How are they connected to your TV? I've seen badly terminated cable / loose connections play only b/w.
    edited July 2006
    Me too... it's happened with my PS2 from time to time.
    Main Rig
    Pioneer Elite SC-05, Rotel RMB-1075
    RT800i, CS400i, RT35i, FXi50, Klipsch RSW-12
    Pioneer Elite DV F-07, PS3, Wii
    Monster HTS 3500 MKII
    SC Analog 2, BJC Speaker Wire
    Samsung HL61A650
    2nd Rig
    Pioneer Elite VSX-56txi, Pioneer Elite DV-47a
    Cambridge Soundworks, MC150 (Center), MC100 x 4, Mirage LF-150
    Office
    Adcom GTP-400, Adcom GFA-535II, (need a quality CDP), RT55i
    edited July 2006
    The VHS side of the player is connected by RCA cables and the DVD side is connected by a optical cable for audio and a RCA cable for the video. The other day I tried to swap the cables from the VHS side to the DVD side to see if it would correct the problem, but the player still played in black and white.
    Tonight, I might try and plug in another TV to see it still plays in black and white. I am just a little dumbfounded why this keeps happenning.
    edited July 2006
    Everytime I saw this problem the person had a video cable hooked into only the green component video jack, and video in on the tv hence no color.
    Jared
    edited July 2006
    Any reason it works for awhile in color and then only plays in black and white? I had set this up once and it worked fine until recently I tried to play a movie and now I only get black and white.
    I will check how I have the cables setup tonight.
    edited July 2006
    sounds like a problem with the component video in/out. Make sure the cables are properly set up from player to tv.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
    edited July 2006
    broken pin on an S-video cable will do this, but it sound like you're using composite/ RCA.
    Yeah, so I've got nothin'
    Backburner:Krell KAV-300i
    edited July 2006
    Try another tv. It may be the input on the tv you are using.
    Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
    Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD
    edited July 2006
    Thanks, I will try that next. Somewhere I read if you unplugged the player for 30 minutes or so it would reset itself. I left it unplugged for a day and hooked it back up last night, but still black and white. I will try a different TV tonight.
    edited July 2006
    Tried a different TV and still black and white. I picked up some new cables today and will try that tomorrow.
    edited July 2006
    sounds like your DVD player is giving up the farm. may need to replace it. try another DVD player if you have one.
    PolkFest 2012, who's going>?
    edited July 2006
    Well, I learned something today. I never really understood the difference between a component and a composite connection. I had a single composite cable running between the green component on the DVD player and the video jack on the receiver. Once I switched the cable from the green component to the single composite-yellow out, it all worked.
    I also learned something about the player, it had two different blocks of outputs and I thought both had to be connected [one for the VHS side and another for the DVD side] which is where I ran into the problem of using the component out plugs. It helped to read the instructions a little more closely. Thanks for your help everyone.
    edited July 2006
    well with component and composite using the same type of connector (RCA), it's easy to get fooled.. glad you figured it out.. happy viewing
    edited July 2006
    Good deal. You live and learn. Glad you figured it out.
Welcome!
Welcome!
