monitor 10's as fronts..what as rears??
starkiller
have a set of monitor 10's i will use as the fronts of an ht system, a center channel polk monitor speaker, now, what for the rears?? i see that frys has the r15's at a great price but was wondering if the monitor 5 or 7 would be a better match...
thanx!
thanx!
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
Why not do a craigslist search for more 10s? I find them usually running around $100 with the stands in good condition.
As for the Monitor 5 or 7's, they should blend quite well with the 10s as they are using similar parts and will probably work just fine. You want to try to keep the timber the same across all speakers. Good Luck!Lovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II
