RT35i, with CSi3......voice match???
Are these speakers a close enough match or should I get RTi6's. They seem to be the same, just a little older. I built my Home Theatre around the Rt35i's. Is the (small) setting okay, my Denon auto set picked them up at large, should I use small anyhow? Seems like they can handle the power.
My HT
Polk RT35i Front (Small)
CSi3 Center (Small)
Polk RTi4 Surrouns (Small)
Polk PSW303
Sony 42" Wega HDTV LCD
Denon 3805
Denon 1920 Universal Player
DTV H10
Monster HTS 3600
Calibrated @75db's
"Die hard NYGIANTS Fan"
CSi3 Center (Small)
Polk PSW303
Denon 3805
DTV H10
Monster HTS 3600
Calibrated @75db's
Post edited by ril850 on
Hi Ril, welcome to Club Polk. You should set your speakers to small & let your sub handle the bass. As for the center channel, you will get umpteen different answers to that question.
How does it sound to you? If nothing is jumping out at you as sounding anomalous, then I say sit back & enjoy the show!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
It should be alright, the Dynamic Balance keeps all of polk's speakers pretty close, and the fact that they are from the same line is even better. If it sounds good to you, it is good,
enjoy.
Matt
