csi5 question
I've been having trouble with the dialogue from my csi5...so I hope it's something i'm doing wrong. i'm wondering if it matters wich set of speaker connectors you use when hooking up the speaker, the top set or the bottom set?? also, is there any other kind of speaker cable i could use to make the dialoge sound better?? right now i'm using monster cable.
Post edited by jdannyj on
No difference in what set of terminals you connect to. (the terminals ARE connected together right???)
What does the rest of your system consist of? Does it sound better if you use a phantom center? (tell your avr center = off or none) (no need to disconnect the center for this test)
Try angling the speaker toward your sweet spot. The difference in cables should not matter that much as it's not like you are using yarn or anything. Have you calibrated your speaker levels?Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Do you have the jumpers in? That might be part of your problem.
I'm not sure what jumpers are??
please explain... -
The jumpers are the metal pieces connected to each set of terminals.Don't forget to look at My Home Theater
Receiver - Onkyo TX-SR503
Fronts - Polk Audio Monitor 40
Center - Polk Audio CS1
Surrounds - Paradigm Cinema ADP
Subwoofer - Velodyne VRP-1200 -
are you talking about the gold plates that are under the speaker connector nobs on the back of my csi5?? they run from the upper set of nobs to the lower set, 1 on each side..??
Those are the ones.Setup:
2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI -
I will take those suckers off as soon as i get home in the morning...
I will be very happy if that's my problem. I figured it was something i was'nt doing right.. why do they put those gold jumpers on in the first place?? -
No you want them on.Setup:
yah, i just realized that you only want them off if you bi-wire...
oh well, it was a nice try..i will leave them on.
I've just ordered some monster z2 reference speaker cable for my center so hopefully that should help..
I posted this silly question in another area, but as far as the speaker cable goes, am i right in cutting off the ends of the monster cable, in order for the cable to fit into the holes on the back of my csi5??
