Subs for my multiroom lc265i's
Right here goes.
Installed two lc265i's in two different rooms running from two channels each of my plinius odeon 6 channel amp, through a squeezebox each. Controlled by a nokia 770 tablet (which is awsome with the customised skin, thanks to the developer).
I am thinking of adding a sub to each room. Looked at the inwall subs offered by Polk and am impressed. Now with the CSW200 being controlled by the SWA500, I have read all the marketing blurb and brochures but can't figure the solution out. Now is there any way to have the amp control two subs in two zones. In the brochure it talks about it working two subs of the same type. Or should I just buy two amps, one for each speaker.
Has anyone had experience with these subs or can recommend anything else.
P.S. I am very happy with the lc265's but every now and again I just need a bit more bass when I crank it up to a couple of artists that I listen to as I try to shake the house down. Generally with more than one zone playing at once.
