Does this DVD player exist?
Ruin
Ruin Posts: 59
edited July 2006 in Electronics
I want a DVD player that has at least a 5 disk carousel/changer.
HDMI output including upconversion of DVD to HD.
Must play DVD Audio, SACD, HDCD, MP3, etc. etc. Basically, everything.
Anything like this from any highend folks at all, or am I just looking at Yamaha, Sony, etc?
Closest I have come has all the above except HDCD.
Thanks!
Denon AVR4806CI
Denon DVD3930CI
Panamax 5500-EX
Polk LSi25 mains/subs
Polk LSiC center
Polk LSi9 Surrounds on Custom Skylan stands
Mitsubishi WD-65831
Audio Art IC-1 Interconnects
Audio Art SC-5 Speaker Wire
Post edited by Ruin on
    F1nut Posts: 51,686
    edited July 2006
    Fisher-Price might have what you're looking for.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited July 2006
    Some tendencies to consider.
    Centralized systems are more efficient.
    De-Centralized systems are more effective.
    RT1
  • Early B.
    Early B. Posts: 7,900
    edited July 2006
    HDCD should be a very minor consideration.
    "God grooves with tubes."
  • thehaens@cox.net
    thehaens@cox.net Posts: 1,012
    edited July 2006
    Everything except the multi disc capability. But you can get up to change the disc
    Lexicon RT-20 (Get out your credit card)
    "The RT-20 is Lexicon’s top-of-the-line universal disc player. Designed to provide superior audio and video performance with virtually any of the 5” optical media discs, it supports DVD-Video, DVD-Audio, DVD-R/W, SACD, CD, CD-R/W, MP-3, JPEG, Video CD and S-VCD. The RT-20 takes the universal disc player to a new level with a High-Definition Multimedia Interface (HDMI), built-in video processing, and extremely precise Digital-to-Analog converters (DAC)."
    Edit: Disregard, just checked again, it doesn't have HDCD either. Guess it is worthless:rolleyes:
  • unc2701
    unc2701 Posts: 3,587
    edited July 2006
    Again, not a changer, but the Oppo 970-HD does all that plus dixv.
    Backburner:Krell KAV-300i
  • Ruin
    Ruin Posts: 59
    edited July 2006
    Thanks for the replies, except for the Fisher Price one.
    The carousel is actually just so the wife can keep 3 or 4 DVDs in the machine at all times, while I change mine in and out.
    If I can't find this, I may just keep the cheapy carousel that we have hooked up and just add a high end one for my own use.
    Thanks!
    Ruin
    P.S. I will probably never even own an HDCD but I figure heh, why not cover all the bases if I can. I really love DVD Audio the best. I wish that could become a new standard and we could retire CDs.
    R
    Denon AVR4806CI
    Denon DVD3930CI
    Panamax 5500-EX
    Polk LSiC center
    Mitsubishi WD-65831
  • Toxis
    Toxis Posts: 5,116
    edited July 2006
    Onkyo DV-CP802... just no upconversion (which isn't a bad thing).
  • Sherardp
    Sherardp Posts: 8,038
    edited July 2006
    The best option for him would be the Toshiba HD A1
  • shack
    shack Posts: 11,154
    edited July 2006
    The NAD M55 meets all of the audio/video criteria (yes HDCD too). However it is NOT a changer and it retails for $1,799.
    http://www.nadelectronics.com/mastersseries/M55_framset.htm
    F1nut Posts: 51,686
    edited July 2006
    It's my opinion that these all-in-one type units, especially carousel/mega changer types are a compromise at best. Jack of all, master of none. Hence the Fisher-Price comment.
    That's solid thinking.
    You probably own more HDCD's than you're aware of. A lot of them are not labeled as such. DVD-A is dead, it morphed into DualDisc, which has flopped big time.
  • joeparaski
    joeparaski Posts: 1,865
    edited July 2006
    F1nut, I agree on the "quality" of the carousel changers. I use a Sony changer that houses 400 cd's but it goes through an MSB Link external DAC and that made a big difference in the sound.
    Using the "shuffle" mode allows me to listen to music tracks I didn't know I had and I can just let the thing play for hours.
    I have a Sony ES??? for more serious listening.
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • unc2701
    edited July 2006
    You're joking, right?
  • Ruin
    Ruin Posts: 59
    edited July 2006
    Thanks for the continued response.
    I wish DVD-A wasn't dead :)
    As far as the HDCD thing, well perhaps I will use an AVR or Preamp/processor that has built in HDCD decoding, then that won't be an issue.
    As for the suggestion about the HD player. All I can say is
    LOL.
    I am not gonna touch this first generation. I have played with that model a bit and can't stand it. Poor responsiveness, very glitchy, etc. etc.
    Give me 3rd generation or better yet, give me an actual winner in the standards wars, then I might invest in one. Not to mention, the pricing model for the media needs to be a bit more consumer friendly.
    I am sort of looking at the Denon 2910 or 3910 atm as far as my personal player while leaving the wife/kids with the Sony carousel.
    R
    Denon AVR4806CI
    Denon DVD3930CI
    Panamax 5500-EX
    Polk LSiC center
    Mitsubishi WD-65831
  • Sherardp
    edited July 2006
    DId it sound like a joke? No I wasnt joking, the upscaling in that thing is insane. True indeed it doesnt play every format mentioned, however it is a quality DVD player, and it surely is kicking the heck out of Blu-Ray. Rackspace providing go with a high quality DVDp then add a CDp that can handle your audio. Just my 2 pennies.
  • rskarvan
    rskarvan Posts: 2,374
    edited July 2006
    HDCD is a MAJOR consideration. Definitely worth the trouble to get that right. Duh.
  • unc2701
    edited July 2006
    yeah, but upscaling is the _only_ thing on his list that it has... and that thing is super twitchy. I went to check one out at BB and the display one was frozen when I got there, they restarted it, I played around for a few minutes and it locked up again. but then it might just be BB.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited July 2006
    The Denon 2910 would be an excellent choice. Also don't forget to check out the Oppo mentioned above...
  • Paulc35
    Paulc35 Posts: 36
    edited July 2006
    Trust us...This feature is not important. I had many HDCD recorded discs that I didn't even know they were HDCD encoded, but My Cary CDP has an
    HDCD decoder and I don't notice even a tiny difference. The only differences there are..1. Your quality of equipment and 2. The quality of the recording. If you have a good system that is capable of revealing the recording for what it is...Then Bad in Bad out...Good in Good out...Get a quality player without regard for HDCD..If you want a universal without breaking the bank try Denon.
    Happy hunting
    ymmv
    paul
    Yamaha RX-V863
    Polk RTA 11T,AR 310 HO, Polk R 15
    Cardas, Coincedent,Zu cable,HGA
    Oppo 971 DVD,Pioneer Universal,Denon 955, Sony-BDP S550, Panasonic DMP-BD 80k,
    Polk R15
    Athena Center
  • shack
    shack Posts: 11,154
    edited July 2006
    I bought a NAD player because it was HDCD capable. I disagree in that there is no advantage. While not SACD quality, the HDCD is superior to redbook on the same recording....at least on the CDs that I've compared.
  • Paulc35
    Paulc35 Posts: 36
    edited July 2006
    Shack,
    My main point is don't sacrifice player quality to get all the bells and whistles in one bundle, which wont yield any noticable difference. Now in saying that everyones taste or what they hear is subjective. The only improvements I've heard are from SACD,or DVD-A. any HDCD disc that sounds great also sounds great on non HDCD players
    Yamaha RX-V863
    Polk R15
    Athena Center
  • Ruin
    Ruin Posts: 59
    edited July 2006
    I am almost sold on the Denon 3910. I may, just may, get a Yamaha DVD-C950 for the wife/kids so that they can more easily acomodate playing on the upcoming HDTV. Gets them some scaling, HDMI etc, while I get the 3910 for superior quality, especially sonic quality.
    Ruin
    Denon AVR4806CI
    Denon DVD3930CI
    Panamax 5500-EX
    Polk LSiC center
    Mitsubishi WD-65831
  • reeltrouble1
    edited July 2006
    I am sooooooooooooooooo glad I am not a videophile Thank You Jesus.
    RT1
  • shack
    shack Posts: 11,154
    edited July 2006
    Paulc35 wrote:
    Shack,
    My point WAS and still IS that HDCD is better than the redbook on the same CD and is worth having. So much so that I made sure my CDP was HDCD capable.
  • reeltrouble1
    edited July 2006
    Ding....We Have a Winner excellent machine there Shack.
    RT1
  • Paulc35
    Paulc35 Posts: 36
    edited July 2006
    Ya Know I went back and pulled my HDCD discs and played them through my
    Cary CD 308 with HDCD Decoding and by damn I think there is an improvement imagine my surprise. My friend has the Denon player and its nice. I just have that ole Oppo and Pioneer....
    YMMV
    Paul
    Yamaha RX-V863
    Polk R15
    Athena Center
