Hardwood floors or carpeted?
frdranger
Hey gang,
It's been a while since I've posted; been busy with alot of stuff. Anyway, I'll be moving in a few weeks into a new house that has hardwood floors. Would you recommend hardwood floors or carpeted floors for better bass reproduction? And if carpeted, what type of carpeting? Thanks guys!
-Tom
-Tom
My Living Room 3.1 config:
Toshiba 40RV525U
Receiver: Onkyo TX-NR609
Center channel: Polk CS1
Front L/R: Paradigm Reference Studio 20
Subwoofer: Velodyne DPS-10
Rears: None
My Computer setup
Klipsch Pro Media 2.1 THX
Toshiba 40RV525U
Rears: None
My Computer setup
Post edited by frdranger on
Neither affects bass as much as it affects highs. Actually bass reproduction is affected more by room dimensions than any wall , floor or ceiling covering.
If you like the look and cleanliness (allergy control) of the hardwoods, I would look into area rugs with or without pads to temper reflections and focus on speaker/sub placement.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
ohh okay, I gotcha. So the sound coming from my center and floorstanding speakers will sound noticeably different on a hardwood floor compared to a carpeted? I am on a carpeted floor right now.My Living Room 3.1 config:
Toshiba 40RV525U
Rears: None
My Computer setup
Klipsch Pro Media 2.1 THX -
You will get more reflectied highs from the hardwoods than carpet. Sometimes good, sometimes a nuisance, each reflection tends to cancel or obscure the original signal and can make your highs sound fuzzy since theay arrive at your ears at slightly different timings. Soft speakers can come alive on hard floors though and some find this helpful.
Bass frequencies are so long ( 20 feet or more) that a thin layer of carpet doesn't usually have alot of damping affect unless you have a downfiring sub.
I wouldn't plan on any type of covering change until you find that you don't like the sound once you set things up, then go crazy trying different options out.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
I think it's a bit of a misnomer that hardwood floors enhance the bass. Personally, I've experienced the most bass in homes where the living rooms are carpeted, but the crawl space below the room allows the floor boards to really resonate because they don't have a solid foundation just below them. I much prefer the absorption of carpet for highs and mids, as the reflective surface really brighens the sound, especially with Polks, which are already a bit bright.Current System:
CSi5-Center (for sale**)
FXi3-surrounds (for sale**)
Martin Logan Depth-Sub
B&K AVR 507
Pimare CD21-CD Player
Denon 1815-DVD Player
Panamax M5500-EX-Line Conditioner -
Thanks for your replies guys, I will test and see how it goes then decide from there. Thanks!!My Living Room 3.1 config:
Toshiba 40RV525U
Rears: None
My Computer setup
I would not replace hardwood with carpet just because of sound reproduction, unless they are in bad shape. Even then, a reason to put better wood on the floor. Like said, rugs will do the trick and you get to enjoy both the sound and beauty and feel of wood floors.
What Sami said...
Rugs are the way to go. Still can use your speaker stand carpet spikes (depending on the length and type of rug) Hardwook looks and sounds (?)
better!
