Klipsch Lahalla's (sp)
I-SIG
I-SIG Posts: 2,243
edited July 2006 in Vintage Speakers
I may have spelled it wrong in the subject, but I met someone who might be looking to sell his. They are 30 years old in great shape. Just a couple of niks in the plywood.
I told him I might be able get him in touch with a buyer. :)
Wes
Link: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
Post edited by I-SIG on
  • DollarDave
    DollarDave Posts: 2,575
    edited July 2006
    I had a pair..real rockers. How much are these?
  • steveinaz
    steveinaz Posts: 19,546
    edited July 2006
    La Scala
    They frickin rock.
  • danger boy
    danger boy Posts: 15,722
    edited July 2006
    they are frickin' huge too. big box speaker..
    PolkFest 2012, who's going>?
  • madmax
    madmax Posts: 12,434
    edited July 2006
    I wonder how much they go for?
    madmax
    Vinyl, the final frontier...
  • steveinaz
    edited July 2006
    I think Klipsch still sells them...
  • steveinaz
    edited July 2006
    yep, the La Scala II...http://www.klipsch.com/product/product.aspx?cid=969&s=specs
    105dB @ 1watt, talk about efficiency! $5,500/pr.
    mhardy6647 Posts: 35,241
    edited July 2006
    Well, not technically boxes; they are three-way horns. Unfortunately the bass (folded) horn is a bit too small (compare a LaScala to a Klipschorn).
    Audiokarma and Audio Asylum member Tom Brennan likens the sound of the LaScalas to a Sawzall. The MF and HF horns overwhelm the bass, and the bass doesn't go too low.
    IMNSHO, the Cornwall is better balanced; even though the bass is flabbier, there's deeper bass from a Cornwall.
    If you really want horn-loaded bass (and there's a lot to be said for it), the venerable Klipschorn is (IMO) a better way to go.
  • steveinaz
    edited July 2006
    You definitely have to like the "Klipsch" sound to get into them. I never cared much for horn loaded speakers, personally.
  • twochannel
    twochannel Posts: 170
    edited July 2006
    A customer of a store I installed for had two pair of Corner Horns and one pair
    of La Scalas in the same room and would play them so loud that his ears bled.
  • madmax
    edited July 2006
    Buzz Saw huh? Doesn't sound too satisfying. Are there any high efficiency speakers out there that sound good too?
    madmax
  • Refefer
    Refefer Posts: 1,280
    edited July 2006
    I liked the Forte II's when I had them for about 6 months. My grandparent's also had an original K-Horn which sounded incredible, especially after the xover upgrades.
    Just don't sit too close.
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
    edited July 2006
    madmax
    Oh, yah! Altec made plenty; I am particularly partial to the 604 Duplex (coax) drivers, but that's just me. I have a pair of 604B's just waiting to have some enclosures built for them.
    The Cornwalls are very good with tubes (I have a pair sitting in the LR).
    Dr. Bruce Edgar's Edgarhorn Titans are among the best sounding speakers I know of.
    Then, of course, some of the classic Tannoys are excellent.
    Electrovoice made some good sounding fullrange and coax drivers, too.
