Best in wall set up
I am wondering what you "well educated" professional's would recommend for an all "in wall speaker" 7.1 set up. I was going to do the LSi (15's and the FX with LSic series but the room is only 16X18. I thought the in wall set up might be a better way to go. I will probably use it about 50/50 TV and Audio. I will be using the
Pioneer Elite VSX-84TXSi
PANASONIC, TH-65PHD8UK PLASMA DISPLAY 65"
I appreciate your help,,, as this will be my first High end system
Post edited by 1967LS7 on
Do 7 of the RTS105 inwall speakers, thats what i am currently installing in a customers room along with some infloor subs.Receiver Yamaha 3070 *Emotiva xpa5 * Behringer iNuke 6000dsp *Monster Cable HTS 3500 -- line conditioner * Panamax 5300 * Apple 4K * Panasonic UB820 * JVC NX5 * Silver Ticket thin bezel 120”
LSIM - Fronts 707 * Center 706c * Sides 702 * Rear 703 *FP RC85i * RP RC65i * Sub (2) SI HT18 -
I was wondering if you could use the same speaker for the center. Would you use the same for 2 of the 7 in the ceiling,. or a round one? Thanx
Whats the budget? They range in price quite a bit.HT SYSTEM-
lsi 9's -
Well I was hoping $3000 max for the speakers,,,all 7
