Outdoor concerts
Lowell_M
I just got home from "Riverfest" where, believe it or not, saw REO Speedwagon in concert. (they are still alive!) Anyway, they can still rock!
So I was standing there thinking... What are used for speakers and POWER for these large outdoor concerts? That's a lot of air to be moving. Do they use giant arrays of woofers to get all that bass? hundreds of thousands of watts?
Anybody have experience with concert sound? Seems like it would be challange to get right.
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
They use 6 sda srs 1.2 tls triamped with cinenova amps to get that true live sound
. SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
most outdoor concerts use about 20 speakers per side for the audience (and most of those speakers have two 12" woofers and a horn..." - so you figure all together, 40 horns and 80 woofers.
Thats not including the large scale speakers on the stage for the people closer up...
The subbage going on is absolutely insane..
LOTS of power... LOTS of speakers.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
