SWA500 Amplifier - Need more info.....
RuSsMaN
RuSsMaN Posts: 17,986
edited July 2006 in Electronics
Is there a picture of the rear of the unit? I remember it from the Maryland gathering, but can't remember the configuration on the rear.
Couple of questions:
1. It states on the product page that you can run 2 subs from the amp - is it configurable for either Stereo or Mono operation (if one was wanting to run a pair of subs in stereo) - or are both outputs mono?
2. Do you HAVE to have an SPEX card inserted to operate? Eg:, is there a default SPEX card WITHOUT any custom equalization for the CSW100 / 200?
My 2ch wheels are turning......
Cheers,
Russ
Post edited by RuSsMaN on
  • steveinaz
    steveinaz Posts: 19,538
    edited July 2006
    Pic from the manual, not great but may help
  • RuSsMaN
    edited July 2006
    Clearly marked L and R, isn't it?
  • steveinaz
    edited July 2006
    Dude, I'm not even sure I know what it is...
  • unc2701
    unc2701 Posts: 3,587
    edited July 2006
    If you're thinking what I think you're thinking, you might be better off with a BFD and a power amp of your choice.
    Backburner:Krell KAV-300i
