Help with Marantz 2270
sda2mike
my 2270 is currently on the disabled list. the right channel is all scratchy. i'm trying to see if i can run the pre outs to the input of a sonic t amp, just for testing. i've been wanting to upgrade power, if the preamp on the marantz works, i'm back in biz...then i need an adcom 545:D THANKS!
Post edited by sda2mike on
Scratchy means dirty, hum ,smoke or nothing means trouble. Sounds like you just need to clean the pots and rca's with Caig's or tuner cleaner.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
I'll agree with the above, but here's another possibility that I ran into with an older Pioneer integrated: I can't remember if the Marantz uses a relay that disconnects the speakers for a few seconds after power-up or not (pretty sure it does), but my Pioneer does, and the contacts in that relay were dirty. Apparently one channel was worse than the other, and it produced a scratchy, sort of intermittent kind of sound, ESPECIALLY for a few minutes after the unit was powered up. I removed the relay (soldered in), took it apart, cleaned the contacts, gave them a shot of Pro Gold for good measure, and reinstalled the relay. Since then I haven't had any trouble with it.
Jason
P.S. I would recommend against using just any tuner cleaner. Get good stuff, like Caig. -
that could be it! i didn't mention that it makes the scratchy noise in any volume position. the controls have always been quiet. can i clean the relay while it's still attched? THANKS!
As far as I know, relays are generally meant to be replaced and not repaired, HOWEVER- Most of them seem to have a plastic cover that's held on by little tabs or ears and can be removed to expose the "guts". That's the way mine was. I had to remove it from the PCB in order to remove the cover. Once it was out I just gave the contacts a shot of Deoxit and a wipe with a lint-free cloth. And like I mentioned, a quick coat of ProGold for good measure.
One of the ways that I discovered the problem was with the relay was to tap on it. I could make the scratchy sound worse or eliminate it entirely depending on where and how I tapped on it.
Jason -
Thanks for your help!:D
