using 2 monitor 30's for rear (6.1)
I have a cs1 center, monitor 40's front/left, and I am going to replace the surround L, and surround R with monitor 40's. Can I somehow hook up both my monitor 30's onto the surround back channel? Or should I just connect one and leave it?
How would I go about wiring the pair if its a good idea? How far apart? The reciever I am using is a yamaha 5740
Post edited by Nate79 on
I would only use the one speaker for the 6.1 surround back.Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
ok cool, what if i use another cs1 center?
its kinda hard to find just one monitor 40 -
Nate79 wrote:ok cool, what if i use another cs1 center?
That would work fine. Keep a look out in the flea market for used centers.Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
i found a single monitor 40 for sale. should i use the monitor, or should i use the center? whats the difference between the 2? the center would actually work better since the box is kinda skinnier, and would be easier to hang on the wall
thanks -
I would go with the Monitor 40, it matches your surrounds and goes a tick lower.Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
thanks. thats what i wanted to hear.
