Sacd 50hz Or 100hz ???
marcd51
marcd51 Posts: 12
edited July 2006 in 2 Channel Audio
When people talk about SACD and setting the setting in my Denon 3910 from 50 Hz or 100 Hz which is the better or why does this setting exist what does it do??
My amp is the Denon 3805 connected via Denon Link 3rd generation at the moment it is set to 100hz.
Could anyone out the tell me ???:confused:
Post edited by marcd51 on
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited July 2006
    I might be missing your question but the lower Hz crossover setting has nothing to do with SACD per say, Are you trying to do bass management for SACD? If so or for any other format, its not the format of the disc but the ability of the other speakers in your system that bests determines what you set your bass crossover at.
    If it is set to 100HZ it simply means bass under that Hz will be sent to the sub instead of that speaker. There is some thought that sending bass to the sub free's up wattage for the other channels resulting in better sound, your results may vary.
    RT1
  • reeltrouble1
    edited July 2006
    Oh yes, I forgot, although I am not presently using Denon I do like their gear, congrats on your system and welcome to club Polk, for me SACD is best digital disc format.
    RT1
  • DAMCB
    DAMCB Posts: 35
    edited July 2006
    Hi marcd51,
    If you're asking about the "SACD FILTER" setting of either 50Khz or 100Khz shown on page 42 of the Owner's Manual, these settings are used to allow high frequency cut off above those two numbers being sent to your reciever or preamp.
    In typical Denon manual fashion, they don't explain why you would want to select one or the other. After searching the AVS " Official Denon 3910" thread I found some discussion on this, with most members setting their 3910's to 50Khz. IIRC. the majority felt that the 100Khz might damage their speakers if the SACD disc had defects. I set my 3910 to 50Khz and haven't had any problems.
    F1nut Posts: 50,729
    edited July 2006
    Hz or kHz makes a huge difference.
  • karpiel666
    karpiel666 Posts: 173
    edited July 2006
    :D
    :D
    dvd player: samsung DVD-HD850
    receiver: Denon avr5700
    center: polk cs400
    fronts: polk rt800i
    surrounds: Unknown Polk monitor? series.
    sub: svs pb12 isd/v
    tv: 46 inch samsung
    VR3 Posts: 28,774
    edited July 2006
    If you listen to music with a 100hz crossover point...
    You...
    A) Have very tiny speakers...
    or
    B) Have a horrible subwoofer.
  • schwarcw
    schwarcw Posts: 7,341
    edited July 2006
    You...
    or
    Not so fast! Depending on the placement on the main speakers, Yiu may need to put more into the subs. My SDA-2.3s are 13" from the rear wall to place the front speaker baffle out in fron of the entertainment center. The bass falls of dramatically as compared when the 2.3 are say 6" from the wall. I divert more of the lfe (around 80 Hz) into the subs, blend the sub output to provide a better overall bass management. I do use the "Polk method" turning the sub selector switch to "off", diverting the LFE effects into the front channels. I use the preouts from the front amp to feed the sub. Adjust the crossover and sub level to "blend" the low end. I get a nice balance of bass management. You really can't tell the sub is in the room until you turn it down. I've suggested to many people to give this a try, most were surpised at the results. The Polk people themselves recomment this method over the convention use of the LFE output connector from the receiver for bass management. Don't knock it until you've given it a try. It does take some work with the adjustments. Use a bass sweep for both setups. It will surprise you.
    BTW, I use a SVS Pb-12/isd SUB
    Carl
    VR3 Posts: 28,774
    edited July 2006
    IMO...
    For music, anything above 65hz or so is far to much...
  • aaharvel
    aaharvel Posts: 4,489
    edited July 2006
    IMO...
    62. :cool:
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • reeltrouble1
    edited July 2006
    WAAAAAAAAAAAAAAAA!!!!!!!!!!!!!!!! 62 or 65, I'll let lucas know.
    RT1
  • steveinaz
    steveinaz Posts: 19,538
    edited July 2006
    The setting is 50kHz and 100kHz. He had a mis-print.
    VR3 Posts: 28,774
    edited July 2006
    If you can hear the difference in 50khz and 100khz...
    Let me know...thats like... Superhuman hearing ranges....
  • steveinaz
    edited July 2006
    No ****, I'd be lucky to hear anything above 15kHz...I believe the "default" setting is 50kHz filtering.
  • reeltrouble1
    edited July 2006
    Right on Steve, likely having something to do with unwanted harmonics or such, seems the fellow was a bit confused with Hz and Khz.
    You fellows set your subs for music wherever you like, not an issue for me. I am just to set in my ways for my own good I suspect.
    RT1
    VR3 Posts: 28,774
    edited July 2006
    Lucas's 80hz for subs.... is good movies...
    For me, 80hz in music involved way to much localization. Also has a bit to do with the speakers though and their roll off point.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited July 2006
    The 50khz cutoff is to reduce the high noise floor that is inherent on SACDs all the way up to 100khz. You can't hear it with your human type ears, but if you had an ultra wide bandwidth amplifier and speakers that could produce the signals, (some can), putting alot of wattage into them would fry your tweeters without even making a sound that you would hear.
    Most use the 50khz setting to help with this issue.
  • reeltrouble1
    edited July 2006
    Thank you Dennis.
    RT1
  • marcd51
    marcd51 Posts: 12
    edited July 2006
    Hi To all , And many many thanks for all your help in this matter , 50khz it is then .;)
