The Right Way to Run Two Subs
i have a room that is about 20x20 and all ready running a velodyen dps 10, i wonder if i could run the dps 12 in that size room and how to run it the proper way. the reciever that i have is the onkyo 703, with only 1 sub preout.
thanks guys for all your help.
Post edited by Phoenix on
You could split the signal from your Onk with a standard Y cable. Yes that size room could use two subs. I run two subs, I moved them around a bit then settled on stacking them, I use my subs for HT, you will need to determine whats best for your room based on how you will use them.
RT1 -
You could also run them via speaker line level. Daisy chain them together and spend some time tuning them might get good results.Lovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II -
Due to an awkward room design putting my subs in 2 different locations was not an option so I used a y splitter and stacked mine. My room is approx. 14x17 and running the 2 subs is not overkill.Pioneer SC-37
RTiA9-fronts
CSiA6-center
RT55i-surrounds
SVS PB13 Ultra & PSW650
Monster Power 3250 amp
Monster Power 2250 amp
Monster Power HDP-2500 surge pro.
Denon 3805,CS400i,RT25i's & FX500i's sitting in the basement collecting dust -
my vote is split the output (y -cable) then connect both subs.
It took me a while to find a good place for both my subs. its going to take trial and error with one sub, much less two.
stacking is certainly a viable method. in my rood, it doesnt work asa well as the way I have it now, but it is VERY MUCH worth the effort to try. if it flies, it makes placement real easy.Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
I am getting a second sub for my system and it arrives tomorrow. I intend to place it behind the FL speaker but if anyone has any other suggestions from looking at my room I would appreciate it. What does the stacking thing achieve?Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
wingnut4772 wrote:What does the stacking thing achieve?
Co-located subs work together to produce more SPL with less cancellations.
