FS: Monster M1000CV Component Video Cable
Early B.
For sale is a 1M Monster M1000CV component video cable in very good condition.
Will sell for $60 shipped in USA. PayPal is preferred. PM me if interested.
FEATURES:
Color-coded, application specific connectors for CB, CR and Y component video signals provide easy, error free hookup.
3 silver-coated copper conductors for greater high frequency control.
Nitrogen gas-injected dielectric for maximum signal strength.
Patented 24k gold contact Turbine® RCAs for superior signal transfer.
UL CL3-Rated for in-wall use.
The Silver Video Difference. If you're a video or home theatre enthusiast wishing to recreate the movie theatre experience in your home, it's critical that you hook up your system with cables that optimize your high-end VCR's, laserdisc players and/or monitors. Ordinary cables, even other so-called high performance video cables, are prone to signal loss that can cause inaccurate transmission of video signals. M1000v features our famous Silver Video technology for maximum accuracy and visual impact.
Polished Silver Coated Center Conductors for Superior Picture Clarity and Definition. M1000v features innovative silver-coated copper conductors for improved high frequency control and minimum attenuation. The silver coating maximizes low frequency response and signal strength, while ultra-wide bandwidth capabilities out to 1 GHz make M1000v capable of carrying both baseband and over 1000 cable TV channels.
Super Low Attenuation: N2-Injected Dielectric. Our unique nitrogen (N2) gas-injected foam dielectric offers lower attenuation and a higher velocity of propagation for maximum video signal strength, even over long runs.
Extra Protection Double Shielding. For reliable rejection of RF and EM interference, M1000v provides a full-coverage double shield of 100% foil and 95% tinned copper braid that maintains integrity even after bending and flexing.
Precision 24k Gold Plated Connectors. Our patented 8-cut Turbine® RCA connector has a heavy-mass ground shell and diagonally cut contact points to ensure lower signal loss and a tight fit. Precision-machined S-video, F-Pin, and BNC connectors are also available. All offer 24k gold plating for high conductivity and maximum corrosion resistance.
The New Video Reference Standard. M1000v/sv lets you see films with astounding color and definition for the ultimate viewing experience.
FEATURES:
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
