CSI5 Placement
edited July 2006 in Speakers
I recently purchased the CSI5 along with RTI10's and FXI3's and I highly recommend all of them. I also purchased an entertainment center that has an opening that will fit the CSI5, just barely. The entertainment center also has a heavy cardboard panel covering the back with some wire and ventilation holes. However, I'm concerned that sound quality of the CSI5 is affected being in such an enlclosed compartment. The speaker sounds great, but would cutting some holes in the back panel improve the sound??
    edited July 2006
    it couldn't hurt anything if you did cut holes in the rear panel. not really sure if it will make a difference or not. give it a try.. no one will see the holes anyways.
    if it sounds good already.. why mess with it then?
    PolkFest 2012, who's going>?
Welcome!
Welcome!
