Center Suggestion for RT12 Left and Rights
jmolendorp
jmolendorp Posts: 5
edited July 2006 in Speakers
I just was given a pair of RT12s and I really like their sound. I am wondering what you all would suggest for a center speaker to be paired with the RT12 as the Left and Right Fronts.
I am probably looking at picking up a used polk center and I wondered would I should be looking for.
Thanks,
Jon
Post edited by jmolendorp on
  • GaryZ06
    GaryZ06 Posts: 317
    edited July 2006
    CSi5
    Panasonic 50" Plasma + Pioneer 6010
    Toshiba XA2 HD-DVD
    Panasonic BD30 Blu-Ray
    Pioneer 1014
    Polk RTi12 (front)...Polk CSi5 (center)
    Polk RTi4 (rear)...Velodyne DLS 5000-R Sub
    3 Outlaw M-200 Amps
  • okiepolkie
    okiepolkie Posts: 2,258
    edited July 2006
    The CS225 or CS250 would be the appropriate vintage speakers. They usually come up on ebay for under $100.
    Tschüss
    Zach
  • Sherardp
    Sherardp Posts: 8,038
    edited July 2006
    definitely the CSi5, just make sure you have the space for it though its rather large in size. It will definitely match up with the RTi12s, after you get the center save up for the FXi3 or FXi5s surrounds and youre golden. What kind of AVR are you using to drive the 12s. I have the RTi12s, CSi5, FXi3s as well and Im very content, my SVS PB12 plus 2 sub adds the bass to my setup. You cant go wrong with the CSi 5 though. Let us know what you think.
  • dipiazza
    dipiazza Posts: 363
    edited July 2006
    People.. he has the RT12s... not the RTi12... just a heads up.
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Reciever: Pioneer VSX-D914
    HD-DVD Player: Toshiba HD-A2
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    Subwoofer: SVS 20-39PCi
    2CH Setup
    Integrated: Onix SP3 Tube
    CD Player: Sony CDP-CX355
    Speakers: Onix Strata Mini in PR Finish
    Signal Cable: Classic Speaker, Analog 1 IC
    Headphones
    Grado SR 60, Bang & Olufsen A8, Shure e3
    Other Stuff in Use
    Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060
  • okiepolkie
    edited July 2006
    Right, that is why I suggested the center channels I did.
    Another option I did forget would be the CS245-not the 245i.
    This is the next version of the RT series and the tweeters are very comparable.
    Tschüss
    Zach
