Polk SurroundBar & Sub Connection
GeorgeM
I have a relatively inexpensive sub (Yamaha 215) that I need to connect to a system using the SurroundBar. Questions:
1. The S-Bar is now connected to the 5 speaker inputs on the recv'r (Yamaha 5650) and my intention is to connect the sub via the sub-out on the recv.r. Is this O.K. and if so, should I use a sub cable that has the two-leads that connect to the sub itself (I don't know the advantage of using this) or will the one-lead work O.K.
or
2. Should I connect the S-Bar directly to the sub's speaker inputs as shown as a setup option in the S-Bar instructions and continue from there...
My preference is paragraph 1. but I'm certainly open to any guidance anyone has to offer.
Would appreciate any comments.
-G
or
-G
Post edited by GeorgeM on
For ease of use, I'd go with #1. I have mine this way and it works out rather well.
As far as the 2 leads, check to see if one of them is a pass thru, or sub out -
A single RCA connection is fine for the subwoofer.
I would go with method #1 as it's simple and will work just as well. The advantage to the speaker level wiring method is sometimes a better blend between the subwoofer and your front L&R mains....which in this case make zero difference since it's not a traditional speaker.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Thanks for those responses; appreciate the info.
-G
