which model is this?
danger boy
danger boy Posts: 15,722
edited July 2006 in Vintage Speakers
i honestly can't tell.. looks like Monitor 10, but not sure.
PolkFest 2012, who's going>?
Post edited by danger boy on
    heiney9 Posts: 25,203
    edited July 2006
    Probably, too bad the grills aren't off. It's hard to judge the scale in the pic, it could possibly be Monitor 11's.
  • decato
    decato Posts: 188
    edited July 2006
    I think it is the Monitor 11 as well. The 10 and LF14 never had trim around the base. The RTA 12 did have trim, but even if the HF unit were missing, you should still see a place to connect the crossover to the input terminal.
    F1nut Posts: 50,729
    edited July 2006
    Agreed, Monitor 11's.
  • ohskigod
    ohskigod Posts: 6,502
    edited July 2006
    there is a slim chance it can be the lf14 (?) the one that was the bass only cabinet of the rta12 (without the tweeter and crossover on top). But. most likly a monitor 11
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • Bruce B
    Bruce B Posts: 3
    edited July 2006
    My Monitor 10B grills extend the entire length of the speaker (i.e. - no lower speaker cabinet trim is visible), so I'd rule those out. Based on the group photo of the Monitor Reference Series Loudspeakers on my original Instruction Manual, the only one they could be from that era is the 11.
