Full 7.1 LSi vs. Axiom Audio...
Snagglepuss1318
Im pretty set on buying a Polk Lsi 7.1 system.
15s, C, FXs, 9s, SVS Plus/2
A neighbor of mine is purchasing an Axiom system around the same price range. http://www.axiomaudio.com/epic80_600main.html#
Anyone know about these speakers? Which system is better?
Post edited by Snagglepuss1318 on
Apples and oranges.
If you're gonna do a comparison, Axiom should be compared to the RTi series, not Lsi.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Early B. wrote:Apples and oranges.
If you're gonna do a comparison, Axiom should be compared to the RTi series, not Lsi.The way one uses a product is a much more SIGNIFICANT factor than which product(s) he uses. -
I disagree...Axioms should be compared to the Monitor series....they are extremely bright speakers....Monitors are probabily built better too...System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD -
Let's see:
Laminate, bright speakers with cheap drivers and foam-bordered ports
or
Laquer finished wood cabinets with ring radiator tweeters and a much better build quality.
Hmm?
Sorry, it may be a bit biased but the LSi are a much better speaker line. The tweeter alone is quite apart from tweeters in that price range, and more akin to higher end speakers. The LSi are much more musical, open and warm, and would offer better dynamics for theater experiences as well. I say go LSi and don't get suckered in by a crap company's superior advertising. Ever heard of Bose? Have you ever actually heard music played from them? One of the most disparate examples in all of electronics: Extremely popular due to marketing, but pretty damn terrible in quality.
Only thing: if you want to get great performance out of the LSi's treat them to good amplification and speaker cables. If you're going Denon 3806 and Monster XP cables, don't waste your money on great speakers, cause they won't sound great.Current System:
CSi5-Center (for sale**)
FXi3-surrounds (for sale**)
Martin Logan Depth-Sub
B&K AVR 507
Pimare CD21-CD Player
Denon 1815-DVD Player
Panamax M5500-EX-Line Conditioner -
When you can buy a speaker with 3 drivers (two of which are midbasses), that is also a decent size and it STILL weighs under 20 pounds...
SOMETHING should send up red flags.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Can't speak on the sound of the Axioms, but the LSi's will look way way better, way better built, and sound great. They're an incredible bargain at used prices if you can snag 'em.Tannoy Dimension TD10, SOTA Star Sapphire, Heathkit W4A's, McIntosh MC2100, Eddie-Current Zana Deux, Singlepower SDS, Sennheiser HD650, Audio-Technica L3000, Sony Qualia 010
Vr3MxStyler2k3 wrote:When you can buy a speaker with 3 drivers (two of which are midbasses), that is also a decent size and it STILL weighs under 20 pounds...
rightO.
hell the small rti4's weigh 15lbs with a tweet and one 5 1/4". -
John K. owns Axiom's, 'Nuff said!!!Political Correctness'.........defined
President of Club Polk -
F1nut wrote:John K. owns Axiom's, 'Nuff said!!!
John K?Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
Which axiom are you refering to? I didnt see any in that set under 20 pounds.Terps Swimming!
HT Setup
TV: Vizio VX32L
Reciever: Pioneer VSX-D914
HD-DVD Player: Toshiba HD-A2
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
Subwoofer: SVS 20-39PCi
2CH Setup
Integrated: Onix SP3 Tube
CD Player: Sony CDP-CX355
Speakers: Onix Strata Mini in PR Finish
Signal Cable: Classic Speaker, Analog 1 IC
Headphones
Grado SR 60, Bang & Olufsen A8, Shure e3
Other Stuff in Use
Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060 -
Millennia M22 Specifications
Enclosure:
Vortex / Reflex
Max Amp Power:
200 Watts
Min Amp Power:
10 Watts
Freq Resp +/-3dB:
60 - 22kHz Graph
Freq Resp +3dB- 9dB:
50 - 22kHz
Impedance (Ohms):
8 Ohms
SPL in Room1w/1m:
93 dB
SPL Anechoic 1w/1m:
89 dB
X-Over
3.5 kHz
Tweeter:
Single 1"
Woofer:
Dual 5.25"
Sub Woofer :
Dimens. H W D (inches):
19.8" x 7.3" x 8"
Dimens. H W D (mm):
503 x 185 x 203
Weight (lbs) each
16 lbs
Weight (kg) each
7.257 kg
16 pounds...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Thats not in the Epic 80-600 system though is it?
Correct me if im wrongTerps Swimming!
HT Setup
TV: Vizio VX32L
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
2CH Setup
Headphones
Other Stuff in Use
No reason to correct...
That one speaker in particular speaks of Axiom's build quality through out the entire line up.
Cheap finishes, cheap everything.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Ahh, i see the one you are refering to. However, it is not in the system snaggle is comparing to the LSi.Terps Swimming!
HT Setup
TV: Vizio VX32L
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
2CH Setup
Headphones
Other Stuff in Use
Understandable for sure.Terps Swimming!
HT Setup
TV: Vizio VX32L
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
2CH Setup
Headphones
Other Stuff in Use
Axiom is known for a few things...
1) Thin enclosures (alot of resonance)
2) bright sound
3) Cheap finishes and overall build...
4) extremely cheap drivers....- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Holydoc wrote:John K?
Do a search, good for more than a few laughs.Political Correctness'.........defined
Lsi's all the way. Just make sure you have the proper amplification for these.
They're 4 ohms and need alot of clean power (usually over 150 watts per channel from a well designed high amperage amplifier will do nicely).SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
Pshhhhaa..... LSi are far better overall.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
