Need center channel speaker help, advice !!
As noted, I have some of the older Polk speakers; RT-55's,RT-35's,FX-500i's and a CS-400i center spkr.(also a CS-300 currently used in the back).
However,I'm finally going to get rid of my old 32" CRT and buy a new 40" LCD HDTV.
My problem is that the CS-400i is a monster of a center channel speaker,8 5/8" H., and most shelves directly below the TV on the majority of the stands I've found are about 7 1/2" H, 8" at most.
I've hardly been able to find any stands that will accomodate the CS-400i on the shelf directly below the TV.(any suggestions?)
One alternative is to go ahead and buy a new center channel speaker that's voiced matched to my existing speakers and would fit below the TV(which newer Polk speaker would match my speakers?)
I notice that the newer Polk center channel speakers come with kickstands.
"The CSi5 features a unique Adjustable Kickstand for secure balance on today's shallow-depth TVs and monitors".
Are these 'kickstands' stable enough to balance a speaker such as the CSi5(which is no lightweight) atop todays plasma and LCD TV's that are barely over 4" thick?
Is there a 'best' way of positioning center channel speakers with todays thinner plasma and LCD TV's?
Any replies, suggestions, solutions would be greatly appreciated.
Thanks,
brentski
Thanks,
brentski
Center; CS-400i
Main's; RT-55's
Side Surround's-RT-35's
Rear center;CS-300
Sub; SVS PB12-NSD
Main's; RT-55's
Rear center;CS-300
Sub; SVS PB12-NSD
Post edited by brentski on
anyone????Center; CS-400i
Main's; RT-55's
Rear center;CS-300
Sub; SVS PB12-NSD -
Oh man I know the feeling! I also have a cs400i and you are not kidding when you say its a monster. Same thing happened to me, I ordered a new 61" tv (should be getting it in 2 days) and started looking for tv stands, found a few that me and my wife like and when we were about to pull the trigger I remember..oh crap that monster. I had to do a lot of research and let me tell you, you cannot find shelves with 9" inches of clearance.
Then I started looking at replacing the center channel and happen to go by the local Best Buy and there it was the same tv that I ordered on top of this tv stand with huge shelve space! Its from Bush industries model VS74962, I know is way bigger than what you are looking for (58" wide) but for $299 it might be something to consider.
Hope this helps. -
I used a set of L brackets to mount the center over the TV.
Good speaker stores have these brackets that have adjustable arm lengths and can hold 30 lbs or so. Even Lowes and the likes have shelf bracket 'L's. I dint want mine touching the TV adding vibrations it didnt need.
Also you wont get a new center to match Timbre on the older speakers. Thats not true about the match shown in the education section of the site. I had it the other way and wanted to save a few bucks, new speakers older center.Didnt even come close, I could hear the difference and my hearing isnt that good so I ran a phantom center till I got the newer center!! -
The kickstand is located at the back of the CSi5 and as such is designed for deep TVs such as tubes. I have the CSi5 and of all my Polk speakers it's my favorite. Mine's on a shelf below my plasma.Multichannel Music:
Sony SCD-C2000ES SACD
Denon 3803 AVR (pre/pro duty)
Outlaw 755 amp
Outlaw ICBM
Polk LSi15/LSiC/LSi9 (front/center/surround)
SVS PCU
HT:
Sony 9100ES DVD
Outlaw 990 pre/pro
Outlaw 7100 amp
Panasonic TH-37PX50U plasma
Polk RTi8/CSi5/RTi6/FXi5(front/center/surround/back)
SVS PCU -
This is the guy and mounts I got them from, just found another link to them
http://cgi.ebay.com/Center-Channel-Speaker-Wall-Mount-Bracket_W0QQitemZ130002254189QQihZ003QQcategoryZ14997QQtcZphotoQQcmdZViewItem -
I have my 400i in the middle shelf with this unit from sanus.
http://www.racksandstands.com/Sanus-NF213c-SY0026.html
JT -
Brentski
This is the pic of my 400i in the sanus stand.
JT -
