lsi rti best choice
mailman23
mailman23 Posts: 93
edited July 2006 in Speakers
LSI 9, LSI15 or any of the rti series.Which is pound for pound the best for the money.I have a 24 by 13 room.the rears have to be in ceiling.I was planning on getting a used external amp if needed.If the lsi's are as good as people say, do they warrant the price increase.
Post edited by mailman23 on
  • mailman23
    mailman23 Posts: 93
    edited July 2006
    also it looks like the lsi 15's are the same as the 9's, with just an 8 inch sub on the bottom.would the 9's and a awesome sub be just as good??
  • aaharvel
    aaharvel Posts: 4,489
    edited July 2006
    welcome. If your budget allows, go with a system based around the lsi's and separate amplification. I would rather have a pair of 9's and a good sub than the lsi15's.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • janmike
    janmike Posts: 6,146
    edited July 2006
    Welcome to CP. I agree, LSi series. But one thing, make sure you have adequate gear to drive them (amp, processor, AVR...).
    Michael ;)
    NORTH of 60°
  • mailman23
    mailman23 Posts: 93
    edited July 2006
    will the 9's fill that space well enough
  • janmike
    edited July 2006
    My room is about 18.5 X 14.5 and there more than enough with the 9's up front.
    Michael ;)
    NORTH of 60°
  • mailman23
    mailman23 Posts: 93
    edited July 2006
    how would 9's up front, lci ceiling speakers and another pair of 9's in rear sound in 7 channel stereo mode.I am hoping to create an awesome sound stage
  • janmike
    edited July 2006
    I am going through the upgrade and I put the 9's up front, LSiC in the middle and am waiting for the LSIFX's to hit my door. I tried the 7CH thing with the RTi series and it did not do anything for me. To each his own. Actually the sound stage with just the LSi9' and the LSiC is better than the 5.1 with the RTi speakers I had. The rears will really bring things together.
    Michael ;)
    NORTH of 60°
  • Joey_V
    Joey_V Posts: 8,586
    edited July 2006
    Looks can be deceiving. Remember that the 15s utilize BOTH drivers for midrange while the 9s utilize ONE.
  • mailman23
    mailman23 Posts: 93
    edited July 2006
    actually according to specs and description, the 9's use both for mid range as well.they seem to just lack the sub
  • Joey_V
    Joey_V Posts: 8,586
    edited July 2006
    Crossover Driver 1: LPF at 200Hz 12dB/oct,
    Driver 2: LPF at 2.4kHz, 12 dB/oct.
    Tweeter: HPF at 2.4kHz 18dB/oct.
    Those are straight from Polk. One of the 9s drivers have to work the bass up to 200hz.
    On the 15s, the drivers both work above 150hz... freeing them from doing grunt bass work - one stops at 800hz, the other at 2.4khz.
    They're completely different.
  • aaharvel
    edited July 2006
    It's just different crossover points.
    anything between 200hz to 2.5khz i consider midbass - midrange.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • SKsolutions
    SKsolutions Posts: 1,820
    edited July 2006
    +1 on the 9's with sub. Heavy preference over 15's. These are hard enough to place as it is without having to coordinate the imaging of the top end with the corner-loving bottom end. I also prefer the 9's on sound alone, , ,even without a sub.
    I agree with Joey on what should be, but the way I hear it is quite opposite to what I see on paper.
    -Ignorance is strength -
  • Joey_V
    Joey_V Posts: 8,586
    edited July 2006
    True, though crossovers can make or break a speaker.
  • lbouthillier
    lbouthillier Posts: 3
    edited July 2006
    I just replaced a RT35i/CS245i system (with a PW350 sub) with LSi9/LSiC system (same sub). My rears are Rt25 for the moment (I've bought LC80i's for in-ceiling surround, but the new room addition it's all going to end up in isn't done yet, so this is a temporary set-up in the "old" living room). I can say that in this room (23x14, with vaulted ceiling to 12', open floor plan opening the room somewhat wider than the 14' on one side) the LSi9/LSiC combo with the sub are magnificent. It's all powered by a Sony ES-line receiver (5.1), and I'm very pleased, for both music playback and home theater.
    The RT35i system was never very good in this space, so it's nice to enjoy the improvement. The RT25 surround aren't in the same league as the LSi series, so the surround is a little weak, but if the LC80i is consistent with the LSi9/LSiC, then this should be a stunning system when the new space is done and all the speakers match.
    I highly recommend the LSi series based on my experience. I was able to find very competitive prices via eBay (new speakers in unopened boxes) that were somewhat better than the best standard retail prices I was able to find.
    Larry
  • aaharvel
    edited July 2006
    when i get a bigger place i'm gonna set up a separate 2channel system, no sub - probably some LSI9's bi-amped to my Signature 2.1, and just let the receiver tackle the rti home theater system.
    300x2 into a pair of lsi9's would make for a great listening experience me thinks. :D
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • lomic
    lomic Posts: 407
    edited July 2006
    Don't let the size of the LSi9's decieve you, they have tricked me into thinking my HSU STF-2 was on when it wasn't. Pound for pound they can put out some tough bass when called upon.
    Dodd Audio ELP [ Tubes ] // Harman Kardon AVR330 // Parasound HCA-1203A // Denon DVD-2900
    Polk Audio LSi9, LSiC, LSi 7 // HSU STF-2 // Signal Cable Interconnects (SG BW/A2/MP)
  • Toxis
    Toxis Posts: 5,116
    edited July 2006
    You want a good sound stage? Get some 9's or 15's and learn how to set them up. The other speakers are strictly for movies. Music will only sound worse through all speakers. Why? Because your processor will be... processing the sound aka not staying true to the recording.
    I have 9's front and rear now and could not be happier. If my budget allowed, I would've went with 15's up front and still had my sub. The 15's will still be a slightly fuller sound than the 9's with or without a sub. So if your budget is large enough, get the 15's and a GOOD sub. Otherwise, the 9's will be MORE than enough. God I love my system.
  • AlanD
    AlanD Posts: 32
    edited July 2006
    Another vote for the LSi9's. You definitely need good amplification to go with them though. Even the LSi7 needs a good amp to really sing.
