Suggestions for next upgrade.
Paul in Canada
I am looking for some suggestions, I'm not ready to upgrade right now but would like to know what you people think I should be keeping an eye out for.
I have:
Denon 2805, RTi 8, CSi 5, Paradigm Atoms, and Paradigm Sub.
I use my system about 50/50 movies and music. I usually listen to music channels that I get from Bell dish and sometimes I'll listen to cds. I was thinking that maybe I would try and find a amp. If I did get an amp would a 5 channel be what I would want to get or would a 3 channel be enough and how many watts would I want to get. I think the Denon is 90 watts per channel.
I was also thinking of upgrading my surrounds after getting an amp. Would using the RTi 8s as surrounds and getting Rti 10's be a good idea or would it be a waste of a great pair of speakers.
I have:
Polk RTi 8's
Polk CSi 5
FXIA4"s
Outlaw Audio M200 x2
Denon AVR 2805
Sony CDP C345
Paradigm PW2200 Sub
Panasonic 50"
"It's futile to have a battle of wits with an unarmed person." demaples July 29/08
Polk CSi 5
FXIA4"s
Denon AVR 2805
Sony CDP C345
Paradigm PW2200 Sub
Panasonic 50"
Post edited by Paul in Canada on
I think a two channel amp would probably satisfy your needs. You could adjust the center channel to blend with the two fronts. The Denon should give you the surround effects that you need. I would suggest a two channel amp of 200 wpc or more. I would also suggest RTi4's or RTi6's as surrounds. Bith the 4's and 6's can be had on eBay for a reasonable price. Good luck1Carl
I think I'd agree with what schwarcw said. I would either focus on an external amp or speakers next. Either would probably do your system good, and you're going to need to do both, so just whichever you want to do first.
200wpc from an external would certainly make your speakers sing. Two channel or three channel is what I'd be looking at. I might lean towards a three channel, just so that all three of my front speakers are getting the same juice.
As for surrounds, yeah, RTi8's would make for some thunderous surrounds, but you'd also need to have a lot of juice to make it worth while. It'd probably suit your needs better to just replace the Atoms with RTi4's or RTi6's as schwarcw mentioned. With a good sub, you won't really notice a big difference moving up to RTi10's up front anyways.
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
I would go the three channel route if I were you. I added a stereo amp for fronts and a mono for center to my system, and it's much improved for both movies and music. Dynamics are great compared to just running off the AVR. I would've gotten a three channel if I found one that met my needs and budget.
I think Satan makes some 3-channel amps that are supposedly going for good prices on ebay. B&K has some good 3-channel options on ebay/audiogon, and Adcom makes some as well.
Monster Power Signature 3 Channel Amp MPA3250
B&k 200.3, 125.3, 1430
Adcom 5503
just to name a few.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
Paul in Canada wrote:I am looking for some suggestions, I'm not ready to upgrade right now but would like to know what you people think I should be keeping an eye out for.
I have:
Tough call, Paul. As long as you have a good subwoofer, upgrading from RTi10's does not really make sense. I would recommend getting matching timbre surrounds instead. A seamless sound field is awesome.
As far as amplification goes, you have been given some really good advice in this thread. Buy the best amplifier you can afford. There is not a big need to constantly upgrade amplifier like you do with speakers and even pre-amps. Therefore by investing a bit now, you will not have to worry about that expenditure in the future.
Have a good time planning!Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
Ditto on the amplification! However, I would bite the bullet & get a 5 channel amp. That way when you are ready to go to all separates you just have to get a pre-amp!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I would keep the Rti8's up front with the Csi5 and think about adding Rti6's for your surround. While I do think the 8's would make good surrounds, I like the size of the 6's for higher placement. I would also forget about a 3 channel amp and go for a 5 channel, like cfrizz said. You could get into one of the 5 channel offerings from outlaw or rotel for about the same as the adcom 3 channel amp. Check out audiogon and see what you can pick up used for a good deal.
Eric__________________
Pioneer 1015
Rotel 1080
Rotel 1075
Rti10: L/R
Rti5: C
Rti6: LS/RS/LSB/RSB
SVS pb10-isd -
Thanks to you all for your suggestions, they are all helpful. I'll start saving some money and I'll keep my eyes open for deals on amps. It will be a while before I make that purchase but now I have a better idea of what I should be looking for. I will be sure to post when I do make a purchase.
Thanks again.Polk RTi 8's
Polk CSi 5
FXIA4"s
Denon AVR 2805
Sony CDP C345
Paradigm PW2200 Sub
Panasonic 50"
"It's futile to have a battle of wits with an unarmed person." demaples July 29/08 -
Question for Holydoc,
I noticed that your amp is 200wpc and the specs on the Fxi3's says it can take 20-150 watts. This confuses me because it appears that 200 watts would blow out the speaker. Please clarify this as I'm still learning about amps. -
providing an amp that is rated higher than your speaker recommend will not damage your speakers. unless of course you overdrive them. a amp with less output WILL damage your speakers faster than a larger amp with more power. there again as long as you don't drive them to distortion.PolkFest 2012, who's going>?
listen to your speakers, if they aren't distorting more power is better for sureSuperDave
Yamaha RX-V992 (Center,Rears)
Adcom GFA-5500 (Mains)
Denon DVD-1920
Mitsubishi 40" LCD
DirecTV DVR Whole House
Polk LSi25 Mains
Polk LSiC Center
Infinity RS1 Rears
Monster THX Cables
