db212-2?
adampoity
i was thinking about gettin db212-2 and i dont know that much about subs and amps so i was wonderin if anyone can give me some advice on wat they think i should get for these subs thanks for your help.
Post edited by adampoity on
Hey, adampoity. I have the db212-2. I use a kenwood amp from crutchfield.com that delivers 850 watts @ 2 ohms. The amp over powers them, but so far the subs have taken it. Crutchfield.com also has a kicker amp that will give the subs the perfect wattage (750 @ 2 ohms).
http://www.crutchfield.com/S-mCqsntlggqP/cgi-bin/ProdView.asp?g=120&I=113KAC9102
http://www.crutchfield.com/S-mCqsntlggqP/cgi-bin/ProdView.asp?g=120&I=206ZX7501
If I had the extra $200 I would have gone with the kicker amp since it is a lot safer for the subs. -
go for the kenwood amp works with no problems even though its over its peak. its better go go over than under the RMS and its on sale for 200
