db212-2?
adampoity
i was thinking about gettin db212-2 and i dont know that much about subs so i was wonderin if anyone can give me some advice on wat they think i should get for these subs thanks for your help.
Post edited by adampoity on
I dont know who makes the sub youre talking about but I just installed my SVS PB12/Plus 2 minutes ago and I can tell you this thing rocks. The deep bass and the punch is accurate. Im running it at 1/4 the gain on the amp, and it just rocks. My walls are shaking throughout the house here. I havent even gotten it up to reference level yet. If you have the 1199 in your budget go for it.
Im still waiting on my Rti12s and two outlaw M2200's after that I will complete the install and go from there. I have the CSi5 and FXi3, monster 3500 power conditioner, so Im ready to rock the place. Consider the SVS man, you wont regret it.:cool: :cool:
Hey adampoity you're in the wrong section dude. Sherardp, those are the car subs in the custom box that Polk makes.Don't forget to look at My Home Theater
Receiver - Onkyo TX-SR503
Fronts - Polk Audio Monitor 40
Center - Polk Audio CS1
Surrounds - Paradigm Cinema ADP
Subwoofer - Velodyne VRP-1200 -
oh ok, i thought he was posting about a HT subShoot the jumper.....................BALLIN.............!!!!!
