rti8 question
jdannyj
jdannyj Posts: 26
edited June 2006 in Speakers
I've purchased the csi5 center speaker, I'm still having a problem hearing the dialogue sometimes. I'm still running my sony dreamsystems front and surround speakers, soon to replace with polk. My question is.. when i replace my sony fronts with the polk rti8's, will that help improve the dialogue??
Post edited by jdannyj on
  • josh_parsons626
    josh_parsons626 Posts: 219
    edited June 2006
    Well, the L/R are more for glass shattering, music within the movie, wind blowing, that sort of thing, with very little dialogue. The center channel is where all the dialogue comes from. When the L/C/R is timbre-matched they all blend together in what's called your front "soundstage". When in your sweet spot it sounds like all 3 speakers have dialogue, but when you actually put your ear to each individual speaker you'll find only the center channel has dialogue.
    Another thing, on your AVR or pre-pro, whatever you have, double-check your calibrations and you might find your center is turned down too low, or your fronts are turned up too high.
    Hope that helps!
    Don't forget to look at My Home Theater :D
    Receiver - Onkyo TX-SR503
    Fronts - Polk Audio Monitor 40
    Center - Polk Audio CS1
    Surrounds - Paradigm Cinema ADP
    Subwoofer - Velodyne VRP-1200
  • bertram
    bertram Posts: 53
    edited June 2006
    I have the CSi5 which succeeded the LSiC as the center channel in my HT. The CSi5 cleared up all the dialog clarity issues and I doubt you can do better in that respect. Make sure you do level calibrations and then, if necessary, feel free to boost the center's level a couple of db. As far as your L/R, it's worth getting the RTi8s but they shouldn't impact the dialog much.
    Multichannel Music:
    Sony SCD-C2000ES SACD
    Denon 3803 AVR (pre/pro duty)
    Outlaw 755 amp
    Outlaw ICBM
    Polk LSi15/LSiC/LSi9 (front/center/surround)
    SVS PCU
    HT:
    Sony 9100ES DVD
    Outlaw 990 pre/pro
    Outlaw 7100 amp
    Panasonic TH-37PX50U plasma
    Polk RTi8/CSi5/RTi6/FXi5(front/center/surround/back)
    SVS PCU
  • PolkThug
    PolkThug Posts: 7,532
    edited June 2006
    Are you still using the Sony "dream system" AVR?
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited June 2006
    Did you do the set up and balance the speakers as suggested?
    RT1
  • Willow
    Willow Posts: 11,073
    edited June 2006
    That was my ?. Maybe the 5 is not getting enough juice.
