Time to Change SRS
SRS_fan
I wanted one photo before they are removed as the primary speaker in my home
I had to move the speakers closer then normal to get the photo from my digital camera.
Its a partial view of the hardware but basically - Perreaux Amps, Krell Preamp, and more hardware then I have space for.
Original owner, and probably the first or at least one of the earliest purchases of the SRS in Michigan. I also have 4 DBX soundfield ones that are in another room. {Not used-along with the audio pro b2-100 sub}
Post edited by SRS_fan on
ok, I'll bite.
Where are they going?
It wasn't easy to replace & it took something significant to put my Polk SRS-SDA's out the room. {New speakers photo attached}
p.s The SRS DOES sound BETTER in some situations/recordings but overall the Logans are tough to beat.
I still need to eliminate some of the hardware and put the rosewood Denon back in.
I am currentlly rebuilding with a minimalist {albeit expensive } approach to 2 channel.
Room treatments is primary as I have heard the sound that I want -- now its reproducing it consistently. { I replaced the furniture & put in a long leather couch to make the sweet spot a simple matter of moving a bit to the left or right} A single position chair did not have this flexibility. -
To my sons house - I cant Biamp the Martin Logans so one of the Perreaux amps will go with them.
Congrats to your son, and apologies to his wife.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
Coolness...keep in the family.
Perreaux amps are VERY nice.
