SVS sub for a difficult room
bdupuy
bdupuy Posts: 13
Problem: My listening area is about 300 Sq.ft., but it opens up into a kitchen (over a bar) and into a breakfast area, so that altogether it could measure up to 600 sq.ft. The ceiling height is 10' everywhere. There is no usable corner in the listening area. I have identified 2 possible locations for a single SVS PC+ 20-39 against a wall, but one is near a corner fireplace opening and the other is near a large hallway entrance. SVS is not very encouraging that this speaker will have satisfactory loudness in my setting and strongly encourages me to go with a 2 speaker PB model. But I cannot identify ANY suitable location for one of these. Is there another better choice? I have been doing without a sub for a long time because of uncertainties like this. My use is probably 80% HT and 20% music.
Any advice?
Mains: Polk RC65i In-walls
Center: Polk CS400i atop TV
Sub: SVS pb12nsd/2
Surrounds: Polk RC55i In-walls
Receiver: Onkyo TX-SR600
Post edited by bdupuy on
  • PolkThug
    PolkThug Posts: 7,532
    edited June 2006
    Wow! Your listening area is bigger than my whole house. Ever thought about a dedicated theater room in the basement?
  • unc2701
    unc2701 Posts: 3,587
    edited June 2006
    Yeah, I'm thinking you mean cubic feet, but I could be wrong.
    Backburner:Krell KAV-300i
  • bdupuy
    bdupuy Posts: 13
    edited June 2006
    Sorry no basement, but that would be a great idea!
    Sub: SVS pb12nsd/2
  • bdupuy
    bdupuy Posts: 13
    edited June 2006
    Right you are. I meant cu.ft. Just divide by 10 to get sq.ft.
    Sub: SVS pb12nsd/2
  • unc2701
    edited June 2006
    Get the big 'un. The cost difference isn't that bad, and that's a huge space; going smaller and adding another sub if it's not loud enough is an option, but multiple subs can get ugly w/ phase cancelations.
  • wallstreet
    wallstreet Posts: 1,405
    edited June 2006
    I've got a 25-31 in a 375sq ft room with no problems. I've even got one port plugged to tune to 20hz.
  • Sthrndream
    Sthrndream Posts: 70
    edited June 2006
    SVS will suggest to you that if you have anywhere between a 2700 to 4000 ft cubed room--i.e opening to another room--you need a +2 type of sub. A pb12 +2 for example. THe problem is standing waves and how they travel through your open areas. You really need some type of corner for the wave to bounce and travel effectively for that large an area. Bottom Line: Call SVS and fax them a sketch of your room, they will give the BEST advice.
    Hope this helps!:D
  • bdupuy
    bdupuy Posts: 13
    edited June 2006
    Going to a 25-31 was one option I considered, since it it louder than the 20-39. But if you plug it to tune to 20Hz, is that still the case?
    Sub: SVS pb12nsd/2
  • bdupuy
    bdupuy Posts: 13
    edited June 2006
    My problem with the PB12/2 is not the cost. It is the footprint of the thing. I've just go no place to put it. The cylinder is easier to find a place for.
    Sub: SVS pb12nsd/2
  • janmike
    janmike Posts: 6,146
    edited June 2006
    I have approx. 270 sq. ft. and the PB12-PLUS actaully seems to disappear in the corner. People have come in and I have to draw their attention to the corner. It seems big right out of the box, but blends in with the furniture. My opinion is the cylinder would stand out more even though the footprint is smaller, just because of the shape. Good Luck.
    Michael ;)
    NORTH of 60°
  • Sthrndream
    edited June 2006
    not louder but deeper. and deeper is not louder. btw welcome to the forum
  • bdupuy
    bdupuy Posts: 13
    edited June 2006
    Thanks to everyone for your help. I have reconsidered the situation and found a spot for the PB12-NSD/2, which is still within my budget. It will be positioned along the middle of a 10' wall that is bounded by a corner fireplace on one end and a hallway on the other (Not ideal, I know). The long side of the speaker will be flush against the wall.
    All of the flooring in the listening and adjacent areas are wood glued onto concrete slab. There are also some area rugs that are not very thick. I'm thinking that will be a good surface not to introduce room effects. Right?
    I did want to use the Plus drivers, but that pushes the price up by $300, and something I read on another thread suggested that the new NSD driver is much closer to the Plus drivers than the ISD was. I will need to run the signal cable up one wall into the attic and over and down through another wall, but we can do it.
    Sub: SVS pb12nsd/2
  • wallstreet
    edited June 2006
    Yep, you lose some output when plugging ports. With no ports plugged, I tuned the sub, and the gain was set to 9:00 (12 is midway, 3 is 3/4). With one port plugged, the gain is set halfway between 9 and 10. The sub isn't even sweating when correctly tuned.
  • HBombToo
    HBombToo Posts: 5,256
    edited June 2006
    Your house sounds very similar to the one I lived in when I purchased the dual CS+. With the help of a a forum member (Dr. Spec), I found the best position was on each side of my 57" HDEF. That was a purchase that I'm sill amazed by after about 4 years or so...
    HBomb
    ***WAREMTAE***
  • ward91
    ward91 Posts: 338
    edited June 2006
    use a pa sub (or custom built one) with a seperate power amp.
    you can find pa subs cheap on ebay.(proberly already know that, just a suggestion)
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
    VR3 Posts: 29,529
    edited June 2006
    PA subs can get loud yes...
    But low it can not.
  • ward91
    ward91 Posts: 338
    edited June 2006
    ye i suppose so
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
    VR3 Posts: 29,529
    edited June 2006
    The best thing about PA subs is this...
    They use big woofers, medium excursion, low power handling, but INCREDIBLY high effeciency - 100db effecient woofers is amazing. Home Audio woofers are like in the low 90s, high 80s I think. They need alot more power because of low effeciency and because they move around 2-4"
  • ward91
    ward91 Posts: 338
    edited June 2006
    they dont move 2-4 inches if thats what you mean. "do they??"
    car audio subs usualy move about 1inch
    or am i just confused?
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
    VR3 Posts: 29,529
    edited June 2006
    Most high quality home audio subs move about 2" to 4" linear.
  • unc2701
    edited June 2006
    Try more like 2" and below. You can find a few 3" ones, but much beyond that is hard to come by and they're not in high quality home audio subs. Even the freakin' rediculous $7,000 MTX 22" jackhammer is only 5"...
  • Sweeeezle
    Sweeeezle Posts: 28
    edited June 2006
    Im in a similar boat and similar size room. Ive been talking to the guys at SVS and I may be returning my pb10 and replace with a plus/2. Im just not sure yet.
    I have about 3600 cu ft. including an open door to the kitchen area. Heres a link to some pics. If you guys havent used it before a free program from google called sketchup is pretty easy to use once you look over the tutorial. I have some other programs but I used this one so I could share my files with my brother as he wanted to be able to see what I was doing with my free time :) . www.sketchup.com
    http://www.pbase.com/livverlips/stereo_shhhhhhtuff
    I cant wait to get a roof over the place :p
    My place sucks acoustically. Tile floors throughout and my couches dont really fit that well any other way than I have them now. The bass sounds good now but it just doesnt seem as tight as I expected it to. I am limited with my receiver as to how much eq'ing I can do. I have a big peak at about 40hz I was able to tame but the rest of my stuff doesnt sound really great either now that I have them in manual mode. I think the main thing is its just having to move so much air. Im just not sure if it will be worth it to me to spend another $800 (a total of about $1200) to get 7-10db of more clean output. Should I just get another pb10? According to Tom at SVS the PLus/2 will be like having about three of the pb10 units.
    Anyone wanna recommend a decent eq for 5.1 or 7.1 system?
    Mains - Polk SDA2A
    Center - Polk CSi3
    Surround - Polk Monitor 5jr+
    Sub - SVS ISDPB10
    Onkyo TX-SR703
    Sony DVPNC85HB DVD Changer
    Monster HTS 3500 MKII
    Sony 50" KDF-E50A10
  • Sweeeezle
    Sweeeezle Posts: 28
    edited June 2006
    By the way if anyone that has the sketchup program wants to view my file in all its 3d glory you can grab it here.;)
    http://rapidshare.de/files/24003805/room__2_.skp
    I may as well add my stuff in my signature in case anyone wants to know what Im workin or if they feel like making any suggestions.
    Mains - Polk SDA2A
    Center - Polk CSi3
    Sub - SVS ISDPB10
    Onkyo TX-SR703
    Sony 50" KDF-E50A10
  • bdupuy
    bdupuy Posts: 13
    edited June 2006
    Thanks for the tip on this sketcher. I wish I had it before I started talking with SVS. I used the drawing tools in MS Word, which is pretty weak.
    I'm curious as to why you would jump from the pB10 to the plus/2. Tom talked me into the NSD/2.
    Sub: SVS pb12nsd/2
  • Meeks32
    Meeks32 Posts: 330
    edited June 2006
    Dont know if it was mentioned before, but if the only concern with a +2 sub is the footprint then you could always just take off the base plate & set it upright with the ports facing up. I did this & it doesnt take up much more room than my cylinder did.
  • Sweeeezle
    Sweeeezle Posts: 28
    edited June 2006
    Actually in one of my first emails I believe Tom had mistakenly thought I had 7500 cu ft. so I am assuming that was probably the reason he mentioned it. Of course I actually only have 3600. As many emails a day as they reply to they are bound to get a number here or there off :)
    Tom had made a comparison for me which I suppose he wouldnt mind if I just retyped it here. Obviously the 7500 # is incorrect for me but as he later told me the comparison remains the same.
    "With close to 7500 cu-ft total, we would normally recommend a
    PB12-plus/2 or a PB12Ultra/2 for home theater use. Compared to the PB10
    you have, the Plus/2 would be equal to about three of them, and the
    Ultra/2 to close to four. Another way of looking at that is...the
    Plus/2
    will give you 7-10dB more clean output and the Ultra/2 will be around
    9-12dB more.
    Adding a second PB10 will give you a 6dB increase in headroom(clean
    output). "
    I imagine the nsd/2 would probably be sufficient for me as well.
    Ive been trying to do some testing using the roomeq program
    http://www.hometheatershack.com/roomeq/
    however it appears to be very flaky on my mac and it keeps crashing on me. Any other mac users here using the app with good results?
    Mains - Polk SDA2A
    Center - Polk CSi3
    Sub - SVS ISDPB10
    Onkyo TX-SR703
    Sony 50" KDF-E50A10
  • Sherardp
    Sherardp Posts: 8,038
    edited July 2006
    I dont know who makes the sub youre talking about but I just installed my SVS PB12/Plus 2 minutes ago and I can tell you this thing rocks. The deep bass and the punch is accurate. Im running it at 1/4 the gain on the amp, and it just rocks. My walls are shaking throughout the house here. I havent even gotten it up to reference level yet. If you have the 1199 in your budget go for it.
    Im still waiting on my Rti12s and two outlaw M2200's after that I will complete the install and go from there. I have the CSi5 and FXi3, monster 3500 power conditioner, so Im ready to rock the place. Consider the SVS man, you wont regret it.
  • bdupuy
    bdupuy Posts: 13
    edited July 2006
    What I findally did was order the PB12NSD/2. I got it installed and I am very satisfied. With the high output using the 20Hz port setting I am getting, I am not sure that I could not have done as well with the PB12NSD/V, but this is certainly impressive.
    Sub: SVS pb12nsd/2
  • Ron Temple
    Ron Temple Posts: 3,212
    edited July 2006
    Unless you've under-subbed in a too large room, not many people complain about the output or musicality of SVS subs. I put a 20-39+ in a 2000 cube, concrete, family room that opens to 5000 (5' opening). Corner loaded, I get room gain which translates to 110db plus peaks at the LP at -15 from reference. When SVS recommends their +2s in large rooms, they are thinking reference level bass...something my house/room can't support. All their subs over-achieve. I have a friend who used a PB10 in a 5000 cube room with very satisfactory results...he needed more, but it was still very impressive and better than the pair of budget subs I had at the time.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Sweeeezle
    Sweeeezle Posts: 28
    edited July 2006
    yea , I ended up just deciding to keep the b stock pb10 I have and later on when funds permit just adding a second one to the mix. They will be easier to move around. As i said elsewhere I wouldnt really get to take advantage of anything more than that living in a duplex. First im gonna get a BFD to tame some peaks and valleys.
    Mains - Polk SDA2A
    Center - Polk CSi3
    Sub - SVS ISDPB10
    Onkyo TX-SR703
    Sony 50" KDF-E50A10
