Rm6801/rm101
REDWING3139
Anyone had any experince using the RM6801/RM101 I was looking to use them as my rears. Any first-hand information on these speakers would be greatly appreciated. Thank You
Post edited by REDWING3139 on
FWIW, I use them because they are small, high WAF and can be mounted on an articulating mounts.....they sound good for rears...not much there in terms of movies....5ch music, I do notice a bit of size differential as compared to my lsi15s....obviously!! The center I dont like as much...I think its too small, even with the 2 "woofers"....please note that I am 90% music so the rears hardly get used....System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD -
so they won't be any good for surrond because my set-up will be 99% fot movies
well it really depends on how picky you are about the sound of your movies. I think it sounds great. Keep in mind that for most movies, there really is not much signal going to the back. That being said, I know HT enthusiasts want matching speakers for the front and back....my thought is that this matching of speakers is not as important for movies than it is for 5ch music, and the rears are the least critical for movies (you should try to match the center to your mains)...System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
by matching do mean same brand? cause my system will have RTi8's for fronts and Csi3 for center
I'm in the same boat. I have RTi8's in front and CSi3 center, and i need something small for the surrounds due to lack of space. I know the RM 101 and 201's don't match the rest of my system, but the size is perfect. I just hope they won't sound like garbage with the rest of my setup
What are you currently using for rears? I am trying to justify movig up to the FXi3 but the size and price of them are causign hesitation
i don't have rears surround speakers yet. i only had enough cash for the fronts and center
