Polk MMC6500
heXtant
Anyone know of any good 2 Channel Amplifiers that would cleanly power the MMC6500 components?
So far I'm looking at
Alpine MRV-T420
http://www.cbrstereo.com/index.asp?PageAction=VIEWPROD&ProdID=8
Phoenix Gold Octane-R 5.0:4
http://www.cardomain.com/item/PHOR504
Phoenix Gold Octane-R 4.0:2
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=12977
Here are just a few ive been thinking of. If anybody knows if any of these would be my best option or knows of another one that would be my best option then please comment.
Alpine MRV-T420
System in construction..
Post edited by heXtant on
I've had a few Alpine amps. I never had any issues with them. I would have no problem running one of those in my car.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
power it with the polk c300.2 . i have it powered with that, and it just rocks man. i highly recommend it. i can guarantee u will love it.Polk Momo MMC6500
Polk Momo C300.2
Polk Momo MM2124 (2)
Polk Momo C500.1
Pioneer DEH-P7600MP -
Hmmm..... ok.. power it with any Arc Audio amp and you will be happy........:rolleyes:Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
I have a question concerning the comparison of the MMC 6500 and the new SR's The only ones that would fit my truck are the 5.5s are they better than the 6500?
I don't have the money to swap, but am just curious.Alpine 9855 hu
Polk/Momo MMC 460 (Rear)
Polk/Momo MMC 6500 (Front)
Polk/Momo MM 2104 Sub
Amp: JL 500/5
Wires: Street Wires
Sat Radio: Sirius PNP
______________________
Home
Kenwood CD 425M 200 disc cd changer
Denon AVR-2801 reciever
Mitsubishi HS-U577
Toshiba -SD1700 DVD player
Klipsch Speakers
Center: RC-7
L&R:KLF-20
Surrounds:RS-3
Sub: KSW-15 -
I would see if using some MDF rings would allow you to make them fit. The larger cone area will give you better response.
The SR's are a few notches above the MM's. Even if you could not fit the bigger SR, the tweeter on those would be worth the change. There are also systems that would offer benefits over the MM's that wont cost as much. An example would be what I have. These speakers have gotten great reviews in Europe and have hung in there with speakers that cost over twice what these cost.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin
