Speaker Enclosure
clkings
clkings Posts: 15
edited June 2006 in Speakers
I need to build some enclosures for some LC80I's I am putting in a drop ceiling. I only have 7 inches of height to work with. Some dimension suggestions would be greatly appreciated. I am going to build them with 1/2 inch plywood.
Post edited by clkings on
  • ward91
    ward91 Posts: 338
    edited June 2006
    type away into google.
    thats what i do untill i get realy stook then i start phoning up about stuf
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • SKsolutions
    SKsolutions Posts: 1,820
    edited June 2006
    Shallow box construction is tough becaue you have to have enough box volume and you end up having to increase the length or width. This type of enclosure needs to be braced heavily even if you are porting. Do some research prior and good luck.
    -Ignorance is strength -
