I Need a Fan
Early B.
Early B. Posts: 7,900
edited June 2006 in Electronics
My tube amp is parked in an audio rack and it needs better ventillation. I'm looking for a super quiet 6" fan(s) or dual 4" fans similar to the ones used for computers. However, I need one that plugs into a standard electrical outlet. Even better is one I can hang on the wall behind the amp.
I've used the search function here, I checked ebay and amazon, but so far I got nuthin'. Any ideas?
Thanks.
"God grooves with tubes."
Post edited by Early B. on
  • dkg999
    dkg999 Posts: 5,647
    edited June 2006
    Parasound ZBreeze. Check it out at AudioAdvisor.
    DKG999
  • Early B.
    edited June 2006
    Thanks, but the Parasound unit is designed to keep components cool that are directly below it. In my setup I can't place a fan above or below, so I need one that will fit behind my amp. Besides, that Parasound is ridiculously expensive.
  • brettw22
    brettw22 Posts: 7,623
    edited June 2006
    Check out my systems showcase for what I mounted to the back of my TV stand and tell me if those appeal. They're 4" fans and compared to trying to use a computer case fan, they're fairly quiet (ac blowing softly). I tried a 4" computer fan and thought that my tv stand was going to take flight.
  • dorokusai
    dorokusai Posts: 25,577
    edited June 2006
    Plus it's half rack width, which makes it almost useless for normal gear.
  • dorokusai
    edited June 2006
    Early...like these? Quikflow. I would suggest a single 120mm.
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited June 2006
    You could try a squirrel cage fan and use tubing to direct airflow. Could mount it way out of the way with less noise.
  • WilliamM2
    WilliamM2 Posts: 4,782
    edited June 2006
    I use a 120mm 12vdc fan, connected with a 4v to 12v wall wart. Set the selector to 6v, and it is imposible to hear from more than a foot away.
  • Early B.
    edited June 2006
  • WilliamM2
    edited June 2006
    That would work, but if you want to make your own, most already have old wall warts laying round, and the fan can be had for about $5.
  • brettw22
    edited June 2006
    I have that some for free, but if ya don't want them, buy away.
    In case you did a quick scan of the auction, that's for one fan only.....
    Good luck.
  • Early B.
    edited June 2006
    PM sent.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited June 2006
    If you place this behind the amp, I don't see a problem with it. William idea is great, but not as easy as buying one.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • brettw22
    edited June 2006
    Returned......will get back to you this weekend.
  • madmax
    madmax Posts: 12,434
    edited June 2006
    I'm your biggest fan. :)
    madmax
    Vinyl, the final frontier...
  • Early B.
    edited June 2006
    madmax
    Cool. Come to my house and blow on my tubes.:D
  • steveinaz
    steveinaz Posts: 19,538
    edited June 2006
    I don't think you're gonna like the "whirring" sound one bit. I even tried 2 vantech stealth fans for my amp, and the noise drove me nuts. I gave the amp more room instead...
