Rti8's or Monitor 60's
vmore1
vmore1 Posts: 7
edited June 2006 in Speakers
Hello all,
Looking to upgrade my 5.1 system to 7.1. Have the RM6800 system right now. I want to move the front satellites to the back and place towers in the front. I'm looking at either the RTi8's or the Monitor 60's. Is there a big difference in the two? Any recommendations would be greatly appreciated.
Post edited by vmore1 on
  • tommyboy
    tommyboy Posts: 1,414
    edited June 2006
    vmore1 wrote:
    Hello all,
    welcome to the forum...
    I'll just say this now, either get the rti8s and upgrade everything else (speakers, sub, reciever, etc) or don't get anything. the 6800 is a decent system but it would not match the m60 or rti8s whatsoever and your reciever would prolly not be able to power them properly. If you don't have the money, wait.
    I can't give you a comparison cause to tell you the truth, I have never heard either of them.
    tommyboy
    AVR: H/K AVR240
    Fronts: Monitor 50s
    Center: CSI3
    surrounds: R15s
    Sub:Velodyne DPS10
    Dvd/Cd: Samsung HD upconverter (for now)
    TV: 50" Sammy Plasma
    game hardware: 360 and gcn.
    Gamertag: kovster27
  • ohskigod
    ohskigod Posts: 6,502
    edited June 2006
    I dont know. it might not match, but there is nothing wrong with upgrading in steps. I've done it, slight timbre mismatch be damned.
    between the 2 speaks, while the Mon 60 is a pretty good floorstander, go with the RTi8
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • tommyboy
    edited June 2006
    yes Ive done it also, but if he wants to upgrade the fronts, the center should be upgraded as well. Using the 6800 as surrounds would work fine for a while. What reciever do you use to power your 6800s?
    AVR: H/K AVR240
    Fronts: Monitor 50s
    Center: CSI3
    surrounds: R15s
    Sub:Velodyne DPS10
    Gamertag: kovster27
  • vmore1
    vmore1 Posts: 7
    edited June 2006
    Thanks for all the replies.
    I'm using an Onkyo TX-SR602 to power the system.
  • Willow
    Willow Posts: 11,059
    edited June 2006
    I have the 8s I would say get the 8s and don't look back. Or listen to both and buy what you think sounds better.
  • vmore1
    vmore1 Posts: 7
    edited June 2006
    I guess I'll look at the CSi3 center channel as well. What the heck right?
  • tommyboy
    edited June 2006
    ouch, no pre outs...
    Whenever you decide to upgrade your whole system (and when you get rti8s/m60s, I guarantee you will want to:) ) get a cheap reciever with pre-outs and buy a seperate amp to power speakers. If you get the rti8s, you have a good start to a great system.
    tommyboy
    AVR: H/K AVR240
    Fronts: Monitor 50s
    Center: CSI3
    surrounds: R15s
    Sub:Velodyne DPS10
    Gamertag: kovster27
  • REDWING3139
    REDWING3139 Posts: 44
    edited June 2006
    tommyboy
    What would you recommend for a cheap reciever with pre-outs and seperate amp to power the speakers. Also would this amp just power the to fronts then the reciever would power the remaiing 3 speaker and sub?
  • vmore1
    vmore1 Posts: 7
    edited June 2006
    Thanks again all. Just demoed the RTi8s. Wow. The store is reducing them to $520 for the pair (new, not floor models). I'll be picking them up tomorrow. I'll upgrade the rest later on in the year.
  • G-force
    G-force Posts: 82
    edited June 2006
    What store? Do they carry rti10's or 12's?
  • vmore1
    vmore1 Posts: 7
    edited June 2006
    The store is Electronics Expo (http://www.electronics-expo.com/). They have 5 stores in New Jersey but you can order anything from the online store. I didn't see the RTi10s or 12s. They had the LSI15s ($1350 ea.) and a couple from the Monitor line. Thats it.
  • Joey_V
    Joey_V Posts: 8,586
    edited June 2006
    RTi8.
