Monitor 60 or 70?
josh_parsons626
josh_parsons626 Posts: 219
edited June 2006 in Speakers
About to pull the trigger on one of these to go with my CS1 and Monitor 40, but dont really know which is the better. I CAN and HAVE auditioned the 50's and 70's at Circuit City but haven't heard the 60's. Polk's recommended systems they have the 60's and not the 70's. The 60's cost $559.98 on Crutchfield and the 70's cost 799.98 at Circuit City. I'm just wondering though what makes the 70's better than the 60's? I'm using these 50/50 for movies and music. Can somebody help me make up my mind?
Don't forget to look at My Home Theater :D
Receiver - Onkyo TX-SR503
Fronts - Polk Audio Monitor 40
Center - Polk Audio CS1
Surrounds - Paradigm Cinema ADP
Subwoofer - Velodyne VRP-1200
Post edited by josh_parsons626 on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited June 2006
    There is no wrong choice in this scenario.
    The 70's aren't neccesarily 'better' - they will play a little deeper, a little louder, a little more efficiently than the 60's - but the tonal signature is consistent throughout the line.
    Me? I wait for Tweeter to put the T90E (Euro version of the Monitor 60) on sale at $350/pair, and spend my savings buying (or upgrading) my subwoofer situation.
    Welcome to the boards, and thanks for choosing Polk Audio!
    Cheers,
    Russ
  • josh_parsons626
    edited June 2006
    Well honestly I want the fronts to play a little louder cause when I listen to music it's 2 channel only
    F1nut Posts: 51,701
    edited June 2006
    The new and improved Russman. :eek:
  • mutelight
    mutelight Posts: 1,054
    edited June 2006
    I highly recommend the 70s, as I have them. :cool: As Russman said you really can't go wrong. I auditioned the 40s, 50s, and the 70s so I couldn't tell you about the 60s but they are a great line of speaker. As you can see I have the monitor series all around and it creates amazing surround imaging since they are all voice-matched. I found the 70s to have great presence. I recently finished calibrating my system and I literally get goosebumps when I sit back and listen to my music. Even though they are large speakers with fairly good bass response I found that between 50-60hz they begin to roll off so I calibrated my SVS to come in at that point and have established what I find to be a great flat response. Two thumbs way up for the 70s!
    // Panasonic AE8000 // Pioneer SC-57 // Polk Audio RTi A9 // Polk Audio CSiA6 //
    // Polk Audio FXi A6 // SVS PB12-NSD Subwoofer // Logitech Harmony Ultimate // Pro-Ject Debut III //
    // Oppo BDP-103 // Microsoft Xbox One Day One Edition // Sony Playstation 4 1TB SSHD // Nintendo Wii U //
    Photo Gallery
    Movie and Game Collection
  • josh_parsons626
    edited June 2006
    Well see, I was wondering if I should go ahead and get the 70 fronts, that way I can put my 40's for surrounds and get rid of those Paradigm Cinema ADP's? Or go ahead and upgrade my center from the cs1 to the cs2? But then again I have a velodyne vrp1200, should I go ahead and get rid of it and get a better sub? What really should I do first?
  • mutelight
    edited June 2006
    The center is very important in 5.1 playback. Your Velodyne VRP1200 will do just fine as far as filling in the LFE until you decide to upgrade and really pressurize the room and get some true sub sonic rumble. :D It is really up to you what you want to do first. If you listen to a fair amount of music I would recommend replacing your mains first, then center next, and last but most certainly not the least your sub. The 70s will give you great stereo imaging and they will also make the effects in movies significantly more impactful. Just to let you know my 40s as my rears sound absolutely phenominal. :cool:
    Photo Gallery
  • da5176
    da5176 Posts: 42
    edited June 2006
    It may be hard to do, but find some place to listen to the 60s and 70s side by side. If you cant, buy them both and compare in your real world anyway. Take back the pair you don't want. There's probably nowhere better than your listening spot to make a choice. If you have a HH Gregg anywhere close, they will deal on the 60s. Just ask them for their best price and you can usually get like 20% off anything in the store. I have the 60s and love them. Got a good deal on them as well $480 with tax for the pair. Got my TV there for 27% off list price. Good luck:)
    NOT MUCH, BUT IT'S ALL MINE!
    SONY 60" SXRD (HDTV)
    Explorer 8300HD (HD-DVR CABLE BOX)
    Toshiba SD-3750 (DVD PLAYER)
    Onkyo TX-SR702 (RECEIVER)
    Polk Monitor 60 (FRONTS)
    Polk CS2 (CENTER)
    Polk Monitor 30 (SIDE SURROUNDS)
    Polk Monitor 30 (REAR SURROUNDS)
    Mirage Omni S-12 (SUBWOOFER)
    Tripplite HT 1000UPS (POWER PROTECTION)
    Omnimount (CENTER CHANNEL SHELF)
    B-Tech BT34 (SURROUND SPEAKER MOUNTS)
  • Ern Dog
    Ern Dog Posts: 2,237
    edited June 2006
    Here is another vote for the 70's, then Cs2 then sub. I have the 70's and they ROCK! I recall auditioning them up against the 60's and found that the 70's delivered a fuller image and better bass. They were out of stock at circuit city so I bought the floor models for $279.00 each :D
    Also, if you haven't done so already, consider getting an Rti8 for the fronts. There was a recent thread comparing the Monitor 70 vs. Rti8.
    Good Luck- Ern-Doggie
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited June 2006
    70's for music
    60's for HT
    (if 50/50, edge to the 60's with a decent sub)
  • Home Theatre
    Home Theatre Posts: 469
    edited June 2006
    I think Tweeter still has that sale going. I would go with that.
    Everything I own burned in the fire!!!!!!!!!!
  • josh_parsons626
    edited June 2006
    Nope I looked and they have the RTi 8,10,12 and LSi 15,25
  • FicmanS
    FicmanS Posts: 134
    edited June 2006
    Love my 70's MUCH better sound for music I think... I still am amazed at them everytime I listen to something new...
    Rockin' In My House :D
    Pioneer 50 inch Plasma TV
    Denon AVR-3806
    Denon DVD-1930ci
    Polk Montor 70's
    Polk PSW-12
    Polk CS2
    Polk Monitor 40's
    Sirius Satellite Radio, Monster 3500MKII
  • mutelight
    edited June 2006
    Agreed, they are very revealing. :D
    Photo Gallery
