svs pb10 set up?
brian2469
When I do my auto setup the EQ sets the subs db's for (50hz @ -6db), (80hz @ -6db), and (125hz @ +3db). Overall sub channel level is set at -2. Just doesn't seem like I am getting enough bang out of my sub. Does this sound right? If I have to adjust manually I would need to reconfigure my rti 12's which at present are (100hz @ -6db), (200hz @ +6db), (400hz @ +4db), (800hz @ +3db), (1.6khz @ +5db) along with my other surrounds. Any help would be appreciated.
Onkyo 803 reciever
RTI-12's w/audiosource amp 300 x 2
CSI-5 w/audiosource amp 200
TC265i's w/audiosource amp 200 (surrounds)
RC80i's (rears)
SVS pb-10 sub
RC80i's (rears)
SVS pb-10 sub
Post edited by brian2469 on
If you have used other cheaper subs in the past the sound from the svs might seem lacking at first, but it grows on you. You soon realize that you arent hearing the bass as much as you are feeling it. If that wasent the answer to your question then I am sorry but I am tired.dvd player: samsung DVD-HD850
receiver: Denon avr5700
center: polk cs400
fronts: polk rt800i
surrounds: Unknown Polk monitor? series.
sub: svs pb12 isd/v
tv: 46 inch samsung -
karpiel is right. Most HTIB subs and lower end subs are real boomy because they output higher frequencies. (which are easier for our ears to perceive) Whereas with the SVS subs (especially with your RTIs) you want them to kick in around 60hz to get the real low non-directional bass. I would recommend boosting the 50hz xover to get more "oomph".// Panasonic AE8000 // Pioneer SC-57 // Polk Audio RTi A9 // Polk Audio CSiA6 //
// Polk Audio FXi A6 // SVS PB12-NSD Subwoofer // Logitech Harmony Ultimate // Pro-Ject Debut III //
// Oppo BDP-103 // Microsoft Xbox One Day One Edition // Sony Playstation 4 1TB SSHD // Nintendo Wii U //
Photo Gallery
Movie and Game Collection -
You could also try ditching the autosetup. Set everything flat, sub out to zero, sub volume knob at 12 o'clock position.
Thanks I just returned a velodyne dpr-12. It sounded much more bassey but it definately was kinda muddy sounding. My friend said she had a headache from all the bass after one movie. If I set the EQ flat, what do I set all the other freq's at?Onkyo 803 reciever
RC80i's (rears)
SVS pb-10 sub -
You'll have to try different crossover settings and see what you like. ie 80Hz or 60Hz or 40Hz
I understand for the sub, but my other speakers have about five diff settings one for each diff freq. Read my first post for what the settings are for my rti 12's under auto set-up. My reciever won't let me modify any of the auto set-up settings. Where do I start?Onkyo 803 reciever
RC80i's (rears)
SVS pb-10 sub -
I understand everything about what the reciever can do, but nobody seems to understand that there are five different freqs for each speaker other than the sub. These are what I am having problems determining what to set each one at.Onkyo 803 reciever
RC80i's (rears)
SVS pb-10 sub -
As others mentioned try to start with a clean slate doing the following manually.
1) Turn EQ off. I'm not sure how to do this on your AVR, but you should be able to.
2) Set sub's volume knob to somewhere between 1/3 - 1/2.
3) Set all speakers to small and choose the 80 Hz crossover setting.
4) Using a SPL meter, calibrate all the channel levels with the AVR's test tones or test tones from a calibration DVD. You may need to adjust the volume on the sub and repeat the sub calibration in order to get the sub to calibrate properly. For movies, you may want to try to run the sub 3 dB higher than calibration to add a little oomph.
5) Enter speaker distance/delay manually for each channel.
Basically try to ditch the auto set-up and auto EQ and determine if it sounds better. I don't use the EQ at all in my system because it sounds "thin" with the auto EQ settings.
One other thing you may try is to run your RTi 12's with a lower crossover setting (maybe 60 Hz) or run them as large (no sub) for 2 ch music.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5.
