Still confused. 2 MM2104s or 2MM2104DVCs or 2 SRs?
Jarrett
Please help me as I'm new to this. I'm looking for sound quality with the ability to sometimes turn it up and show off without blowing anything at a reasonable price without taking up all my trunk space. I currently have a c500.1 amp and 2 mm2104s (one of which is blown). I plan on having a box built and having them both run off the same amp. Should I stick with my SVCs or go with DVCs and how do you recommend I wire them? Also, if I get these and decide it's not enough will the SR series work out without hurting anything using the same box that I'm going to have built for the 2104s but with just adding a 2nd c500.1 to handle the power? Thanks in advance.
-JAE
-JAE
Post edited by Jarrett on
The SR's are a good bit bigger than the MM's and require a bit more space. Make sure you take that into consideration. If you want to go with the SR's and use 2 amps, youll need to get DVC's for that application.
A pair of MM2124 SVC's will run just fine off a 500.1polkaudio sound quality competitor since 2005
Thanks, even if I go with 2 MM2104s should they be SVC or DVC if I intend to stay with the 1 c500.1?
-JAE -
If youre going to use 2 subs and the 500.1 then youll need the SVC.polkaudio sound quality competitor since 2005
If you go to crutchfield.com, it will explain DVC and SVC subs. Also, it has many different wiring diagrams for each one. They are simple and easy to follow, even for a novice like myself haha.
