Do I have sufficiant power?
da5176
da5176 Posts: 42
edited May 2007 in Car Audio & Electronics
I just had a 4-channel amp installed and the shop strongly suggested that I ad a capacitor to the system. I had installed, a MTX thunder 564 (75W X 4 RMS) amp with 4 awg power and ground wires. I already have a RF P3001 sub amp (300W RMS) with 4 awg power and ground wires. This is all in a 2006 Toyota Highlander 2 wheel drive 4 cylinder, no tow package. I don't know what the alt. power output is. I don't have any lights dimming at any time, but am thinking about adding a satellite radio to the mix. Does my alt. put out enough power for the current power draw I'm using? I don't want to cause any damage to the new vehicle. What would be the best course of action to take? Will I really need a bigger alt. or should I be fine with what I have? I need some thoughts and some suggestions from you guys if possible. Thanx
NOT MUCH, BUT IT'S ALL MINE!
SONY 60" SXRD (HDTV)
Explorer 8300HD (HD-DVR CABLE BOX)
Toshiba SD-3750 (DVD PLAYER)
Onkyo TX-SR702 (RECEIVER)
Polk Monitor 60 (FRONTS)
Polk CS2 (CENTER)
Polk Monitor 30 (SIDE SURROUNDS)
Polk Monitor 30 (REAR SURROUNDS)
Mirage Omni S-12 (SUBWOOFER)
Tripplite HT 1000UPS (POWER PROTECTION)
Omnimount (CENTER CHANNEL SHELF)
B-Tech BT34 (SURROUND SPEAKER MOUNTS)
Post edited by da5176 on
  • da5176
    da5176 Posts: 42
    edited June 2006
    I just found out from my car dealer that my alternator put out 130 amps. Does that sound like enough?
    Polk CS2 (CENTER)
  • PolkThug
    PolkThug Posts: 7,532
    edited June 2006
  • da5176
    da5176 Posts: 42
    edited June 2006
    I was able to verify through my VIN # that my alt. is realy only 100 amps, not 130. Sorry for the confusion.
    Polk CS2 (CENTER)
  • MacLeod
    MacLeod Posts: 14,358
    edited June 2006
    That should still be enough. 600 watts aint going to be that big of a draw.
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited June 2006
    a 100 amp alternator will - all things being equal - more than sufficiently supply up to about 700 watts.
    you're at 600.
    you don't need a capacitor. you don't need another battery. you don't need ****.
    The Artist formerly known as PoweredByDodge
  • DemonAstroth
    DemonAstroth Posts: 131
    edited February 2007
    OK, you seemed to have been able to help him, now...
    If I have a stock 80 amp alternator...
    is that sufficient to power:
    Eclipse amp 760 w rms (380 x2 @4ohm) Pushing 2 10" infinity kappa perfects
    and
    Hifonics tx8805 440 w rms (110 x4 @4ohm) DB's 6500's components rear and infinity's
    My headlights started to dim after I upgraded the subs from some type S's (which were only 200 watts rms each)
    Also (probably set the gain in the amp too much), but i'm getting some clipping when I turn on the volume past 70 (out of 90).
    Demon
  • Joelsbass
    Joelsbass Posts: 637
    if your headlights are dimming you may want to look into getting your alternator re-wound. a decent shop can get you enough of a gain to cover your needs
    MacLeod: I guess youre lucky Polk has such lax hiring standards.
    Josh: Damn skippy!
  • DemonAstroth
    I don't know how much that would cost...
    I could get an higher amp alternator for 200 though.
    230 for a 150amp, and 260 for a 200.
    That would do it no?
    For now... would a capacitor help at all? I know it just gets rid of the symptoms, but is it a viable *temporary* fix?
    Demon
  • PoweredByDodge
    you're a good 20 A under what you need (minimum).
    Grab the 150 A alternator and a nice battery (Optima D34 should do the job - they're about 100 bucks at 1st optima batteries dot com).
    You're not going to cover a 20 - 50 amp (headlights, etc) gap with a capacitor dude.
  • DemonAstroth
    Well... i'm one step closer, as I already have an optima yellow top. I do love being able to listen to music with the car not running and not having to worry.
    Anyway, I'm also thinking about "downgrading" (from a wattage perspective), my 4 channel speaker's amp, as the Hifonics is certainly not of the highest quality and I think I would be fine with something around 75 watts per channel.
    I turned down the gain on the amp and it doesn't clip anymore, but I am still unsure as to where is it supposed to be:
    My head unit has a 4v output, and the amp gain settings show 2v in one extreme, 8v at the other extreme, and 1v in the middle. I had it at 8v when it was clipping.
    Thanks for your input, I will have to be getting an alternator.
    Demon
  • PoweredByDodge
    it probably shows .2 (POINT 2 -- as in 0.2) on one extreme, and 8 on the other...
    0.200 V to 8.000 V is a common range for amplifier inputs.
    peg it about 1/3 of the way between 1 V and 8 V and see how that goes.
  • DemonAstroth
    Thanks!
    That really makes sense, I just couldn't figure it out, and since I cannot find any documentation I was just guessing.
    Demon
  • TrappedUnder Ice
    TrappedUnder Ice Posts: 975
    I have not been on here forever- just kinda looking around. It is so typical of a shop to try and sell caps! You dont ever ever ever ever need a cap like that in your system- you may want one...but you dont ever need one. Caps are just the gheto band aid of the last 5yrs. Just my 2 cents. And for those who know me...its been my stance for quite a long time.
  • MacLeod
    Good to see ya back Thomas. Where ya been?
  • DemonAstroth
    Yes, I have always understood that. Hence why I said it wold be a temporary fix, as it is a lot easier to install a cap than to replace an alternator.
    What I do not understand though, is WHAT are capacitors for? I mean, if all these "reputable" companies are making them and selling them, are they really spending their time into designing a product that is not necessary?
    Demon
  • exalted512
    exalted512 Posts: 10,735
    lol. Never fails, the only time Thomas posts is when someone says the c word!
    -Cody
  • Joelsbass
    People buy them so someone sells them... if there were profit in it I'm sure you could buy toenail clippings from dozens of major manufacturers...
    Josh: Damn skippy!
  • TrappedUnder Ice
    Capcitor has many different applications. A cap would be better used on the mids of a high end system- when I say High end..I'm talking over 5k easy. The purpose of this would be too filter any flutter in the power that may occure during a stong mid range passage in a song. This will help the dynamics and your "head room" effect.
    Alma gates did a study and found that she hit better #'s without caps then with- go figure!
    Thanx for the warm welcome. I've been really into Home Theater and working around the house.
    I sold the Intrigue and now have an HHR- stock Pioneer system- which is fair for stock. No plans too upgrade it at all.
    The Hoe was broken into superbowl a year ago- and we now have an 07' hoe with stock Blows system- no plans too upgrade.
    I have quite a bit of electronics for sale:) those who know me can attest too my worthiness :)
    Peace -
  • MacLeod
    Alma's Bronco is awesome!!!
  • exalted512
    Peace -
    what all did the thieves get? I hate that crap.
    My boss picked up an 07 hoe the other day. Very nice, I love how the radio has presets for XM and FM without having to change the source. Great idea.
    -Cody
  • TrappedUnder Ice
    They got the alpine HU, Sony monitors and the Eclipse EQ:
    Idiots cut the cable too the monitors and left the small boxes under the seats and broke the brakets when they pulled them out- they are use-less now!.
    The eq- was great...but kinda had it for 8yrs or so...
    Damage was the worst- broke the dash plate and cut the leather seats!
    oh well.- too bad you cant have nice things these days.
  • 1996blackmax
    1996blackmax Posts: 2,436
    Hearing about this stuff really makes me upset........why can't they just work for their sh** like we do.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • DemonAstroth
    edited March 2007
    Well....
    My headlights haven't dimmed anymore. I think what happened is that when I installed the subwoofers, I was tuning it for quite a long time, while the car was off. I think I may have almost drained the battery. I have an Optima yellow top though. So once the alternator was able to recharge it I haven't had any problems... even while at idle.
    And the clipping was fixed when I turned the amp to the proper gains.
    I still need some front speakers though.... trying to find a good deal on MMC5250's, but still considering the alpine type S 5.25 component and the Eclipse 3 way component SC8355.
  • DemonAstroth
    edited May 2007
    Well... I couldn't find any deals on the eclipse's nor the mmc's, so I ended up with:
    Alpine SPX-177r
    I got them for 100 dollars so I couldn't pass up the deal.
