Still confused. 2 MM2104s or 2MM2104DVCs or 2 SRs?
Jarrett
Please help me as I'm new to this. I'm looking for sound quality with the ability to sometimes turn it up and show off without blowing anything at a reasonable price without taking up all my trunk space. I currently have a c500.1 amp and 2 mm2104s (one of which is blown). I plan on having a box built and having them both run off the same amp. Should I stick with my SVCs or go with DVCs and how do you recommend I wire them? Also, if I get these and decide it's not enough will the SR series work out without hurting anything using the same box that I'm going to have built for the 2104s but with just adding a 2nd c500.1 to handle the power? Thanks in advance.
-JAE
-JAE
Trying posting you question in the car audio section farther down the page. You should be able to find some help in there.Polk RTi 8's
Polk CSi 5
FXIA4"s
Outlaw Audio M200 x2
Denon AVR 2805
Sony CDP C345
Paradigm PW2200 Sub
Panasonic 50"
"It's futile to have a battle of wits with an unarmed person." demaples July 29/08 -
Done. Thanks!
-JAE
