DB 525 4 Ohm (Can I use in 8 ohm Harley Radio)
jjr
jjr Posts: 4
edited June 2006 in Speakers
I have a 03 Harley Ultra Classic with a 160 watt radio ( 40wpc x 4 - 8 ohm) factory speakers.
I noticed that the 525 speakers are rated at 4 ohm and had also read somewhere that the 4 ohm was a nominal rating???
The maker of the Harley Radio is a company called Radio Sound in KY. I did call them and asked if it would be ok to run 4 ohm speakers om there 8 ohm radio?
I was told that if I did that I would cause a early failure of the radios amp. The person I was speaking with did not sound like a techinical person but in my owners manual that radio is rated at 8 ohms.
I really would like to use the 525's in my bike , perhaps any other HD owners or techinical folks could pass on some info.
Thanks,
John
Post edited by jjr on
  • ohskigod
    ohskigod Posts: 6,502
    edited June 2006
    I assume someone in the Car audio section should know, lord know's I'm cluless :D
    look down the forum list for the "on the move" section, thats where all the mobile audio guru's hang. someone's gotta have some insight for ya there.
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • jjr
    jjr Posts: 4
    edited June 2006
