Source/Amp --- Pre-Amp?
zombie boy 2000
zombie boy 2000 Posts: 6,641
edited June 2006 in Electronics
Stupid question, of which I am 99% sure of the answer...
Is a pre-amp necessary, if you're only using one source (e.g. a CDP) and analog IC's?
Post edited by zombie boy 2000 on
  • ND13
    ND13 Posts: 7,601
    edited June 2006
    Unless your source has it's own volume control, it's good to have one if you like to control the volume.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • zombie boy 2000
    edited June 2006
    Other than volume, would it serve any other function? If the CDP's DAC is running with the ball....
    (and I won't lie to ya, I hadn't thought of volume)
    :o:o:o
  • audiobliss
    audiobliss Posts: 12,518
    edited June 2006
    Kinda depends on the situation and what you want. No, a preamp is not necessary if you're not wanting to switch between sources. However, you also won't be able to adjust the volume. Unless, of course, your CDP has a variable output.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • zombie boy 2000
    edited June 2006
    Tis' what I had figured.
    Thanks guys:)
  • steveinaz
    steveinaz Posts: 19,545
    edited June 2006
    Some amps have level controls as well, Parasound for one....
    It can be done if either the source or the amp have a level control. It also sounds extremely neutral. I ran my system like this for about 8 days while waiting for my preamp. Bit of a pain though, as my parasound level controls are on the back of the amp.
  • 2+2
    2+2 Posts: 546
    edited June 2006
    FYI...Sony ES cd players have remotely controlled variable output so you do not need a preamp....
    System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
    System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
    System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
    System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD
  • Lsi9
    Lsi9 Posts: 616
    edited June 2006
    GEt an amp with volume control for each channel like BK
    Audio Physic Scorpio II
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
